Whole House Dehumidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 08:12 PM   #1
Rewards Points: 370
Whole house dehumidifier
I live in an area where the temperature isn't so much the problem as the humidity and I've been turning on the AC only so that it will pull the humidity down. I found out that whole house dehumidifiers exist but would it be cheaper to run a whole house dehumidifier or just run the AC?
Also, do geothermal systems when cooling remove humidity?
MLMIB is offline   Reply With Quote
Old 06-01-2011, 09:58 PM   #2
Rewards Points: 6,652
Whole house dehumidifiers are what your A/C does. There are some thermostats that allow you to run the a/c as a dehumidifier (the 3m Filtrete 3m-80 does this and some more), besides using it as a heat pump, by measuring the humidity in the house. As for Geothermal, it works the same as a heat pump. Instead of a outside unit, the piping from the inside unit runs into the ground either vertical, in trenches, or under water if in a climate that you do not get a complete lake or pond freeze.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
