Whole-House Air Filter Or Regular Filter System? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 04:05 PM   #1
Rewards Points: 45
Whole-House Air Filter or Regular Filter System?
During the process of changing my return air duct, my HVAC guy suggested me installing Lennox Healthy Climate 10 Media Air Cleaner with Merv 10 rating. Should I go with it, or choose another whole house cleaner, or use the most-simple throw-away filter system that I currently use?
The HVAC guy said the filter of whole-house cleaner only needs to be replaced once or twice a year. I, instead, like these simple air filters that I can replace every 2-3 months. I am not sure whether I am right.
Thank you all!
kgkg is offline   Reply With Quote
Old 08-21-2013, 05:14 PM   #2
An old Tradesmen
Rewards Points: 6,086
The media filters are better. but it is always up to the individual customer.
Old 08-21-2013, 09:19 PM   #3
Rewards Points: 582
we also sell alot of media filters....they truly are better all around...those filters your talking about sound like the pleated filters like 3m and others we get some issues from them they tend to restrict air flow even after they get just alittle dirt on them ...but as bt said its up to the customer...ben sr
Old 08-21-2013, 09:37 PM   #4
Rewards Points: 45
Hi Ben, yes, I was comparing the 3M Filtrete 1-inch pleated filters with 5-inch media filter.
Old 08-21-2013, 09:47 PM   #5
Rewards Points: 16
Could he use a lower merv and eliminate some restriction?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 08-21-2013, 09:54 PM   #6
Rewards Points: 45
After lowering MERV, the filters wouldn't be that effective to remove particles, right?
Old 08-21-2013, 09:57 PM   #7
Rewards Points: 16
Here is a description of merv ratings I run 8 http://http://www.airfilters.com/merv-ratings/
Old 08-21-2013, 10:06 PM   #8
Rewards Points: 45
Thanks! My question is whether MERV 10 is enough or we need MERV 11+ for a regular family with babies (no asthma or particular allergy)?
Old 08-21-2013, 10:09 PM   #9
Rewards Points: 16
Well start at 10 if you see dust or have an issue, move up. I run 8 with the el cheapos in the grills and my big filters go for ever.
Old 08-21-2013, 10:13 PM   #10
Rewards Points: 45
My contractor will install Lennox Healthy Climate 10 Media Air Cleaner with Merv 10 rating. Does that mean I can move up by changing the filter, or do I have to stick with MERV 10 if I install the system? Thanks a lot!
Old 08-21-2013, 10:17 PM   #11
Rewards Points: 16
You can go up on merv anytime you change filters. Merv is the rating for te filter.
Weird wiring in house fdmillion Electrical 13 06-14-2013 07:49 PM
Steam heating system in an old house. Do I add water, and where? Salvatorparadise HVAC 2 12-24-2010 06:51 AM
Best Air Filter for My System? mario390 HVAC 5 10-23-2010 11:22 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
Whole house water filter questions... epeterson777 Plumbing 7 10-12-2008 01:51 AM
