Who To Call - Bad Heil Heat Exchanger - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 08:23 PM   #1
Who to call - bad heil heat exchanger
My Heil furnace is 3 years old and today during a home inspection,
a CO sniffer over the vent detected small levels of CO. I assume the heat
exchanger may be bad. The company that installed the unit is out of business. Do I need to call a Heil dealer, or can most any HVAC dealer
replace the part under warranty?
mainstreetprod is offline   Reply With Quote
Old 01-28-2009, 08:39 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
"During a home inspection"? who was doing the inspection? CO detectors can be inaccurate like any other device, especially when they get old. I would call your gas utility and get them to come and check. They usually have very accurate instruments. 3 yr old heat exchangers do not usually fail. A Heil dealer would need to do the job.
Old 01-28-2009, 08:52 PM   #3
Thanks, the Realtor also suggested calling the gas co. Home inspector
said the detector has only shown CO a couple of times before. Interesting
that he also got a reading upstairs though (differenct unit).
Old 01-28-2009, 09:00 PM   #4
An old Tradesmen
Rewards Points: 6,500
Good chance the CO was coming from some other appliance, or area.
Such as a car having bee run near the garage, while the door was open.
Gas range/oven not working right.
Water heater.
Old 01-29-2009, 12:19 AM   #5
Dr Heat's Avatar
Go to goheil.com they have a dealer locater. Typically with Heil if you have a bad HE. you will trip the role out. But have it checked.
Dr Heat is offline   Reply With Quote
Replace Heat Exchanger or Furnace deccher HVAC 41 10-22-2013 09:45 PM
Carrier Heat exchanger ericcolon HVAC 1 01-28-2009 11:44 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Is there such a thing as a dirty heat exchanger? suthrnreject HVAC 8 01-19-2009 09:23 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
