White-Rodgers Zone-A-Flow Seal Kit HELP - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 09:09 PM   #1
I need to replace the seals on a White-Rodgers Zone-A-Flow valve.
Type 1361-104. If I shut off the water (and power) to the valve and remove the valve (after the hot water cools) I will drain the pipes in my Hydronic baseboards. This I believe is going to cause a problem. What is the proper way to do this? The boiler is a Hydrotherm 100.
thank you.
D
StahlMaster is offline   Reply With Quote
Old 11-16-2012, 09:36 PM   #2
Did you every get a response to this? I need to seal a leak in my system from the same model valve. Any suggestions or directions on accomplishing this? Thanks. Here was your original post in case you forgot:
sjack1996 is offline   Reply With Quote
Old 11-16-2012, 09:52 PM   #3
I never got around to replacing the leaking valve. It only leaks a drop or two every so often so Im going to leave it for now. It's an easy fix if you know which valves to close and how to refill the system. I may try it when the weather warms up. I found a replacement valve for $90.00 but a seal kit is available for a few bucks. It's just an o-ring. Hope this helps.
D
Old 11-17-2012, 06:59 PM   #4
Thanks. I have a seal kit on the way and am going to attempt to drain, fix, and refill. If I remember, I will let you know how it goes.
Stan
Old 11-17-2012, 07:10 PM   #5
Stan
Please do so. Take photos if you can. Good Luck!!
Painting white martinigirl Painting 3 04-26-2009 06:24 PM
Making a blower work with a White Rodgers 50A55-405 Controller gegnerx HVAC 3 01-13-2009 03:58 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 07:54 AM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 08:24 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
