White Rodgers Div 1e30w-311 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 01:23 PM   #1
white rodgers div 1e30w-311
I have this old white rodger, It has no labels on the old stat, It has a red a white wire coming out, How can I follow the wire to see if it is down stair in my furnace?
Or does anyone know what the wire are label to be, right side? left side?
anyways it is hook to gas and run by electial?
homeown is offline   Reply With Quote
Old 09-13-2010, 05:36 PM   #2
An old Tradesmen
Rewards Points: 7,814
If it only has 2 wires. The red should be the 24 volt hot, and the white should be teh 24 volts back to teh W terminal of the furnace.
White Rodgers 1F95-1291 Tstat Dual Fuel problem mgroves HVAC 11 02-05-2011 09:00 PM
Need help wiring Honeywell Thermostat from White Rodgers mrx900 HVAC 5 06-06-2010 03:57 PM
White Rodgers 50A50-405 heat blows cold Kbrodsky HVAC 5 05-04-2010 06:19 PM
Making a blower work with a White Rodgers 50A55-405 Controller gegnerx HVAC 3 01-13-2009 03:58 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
