White Rodgers 50A50-405 Heat Blows Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 09:19 PM   #1
White Rodgers 50A50-405 heat blows cold
My gas heater unit stopped working. It continues to blow cold air with thermastat turned up. No problem with a/c. I tried all the basics I could think of shut breaker, checked connections ect. Any advice would be appreciated. Does this sound like a mother board problem?
Kbrodsky is offline   Reply With Quote
Old 04-29-2010, 06:45 AM   #2
An old Tradesmen
Rewards Points: 6,072
Made this into its own thread.
Does the HSI glow?
Old 04-29-2010, 08:05 PM   #3
White Rodgers*50A50
Thanks for your response.
No glow from hot surface ignitor. Sound like fan noice first followed by blower eventually kicking on with cold air.
Old 04-29-2010, 08:49 PM   #4
An old Tradesmen
I'd check the HSI, see if ts bad or not.
Old 04-29-2010, 10:09 PM   #5
Ok, thank you I will start there and follow up when I replace the HSI.
Old 05-04-2010, 07:19 PM   #6
Thumbs up
Thanks!! Fired right up
was bad HSI.
The Following User Says Thank You to Kbrodsky For This Useful Post:
marinpetkov (12-30-2011)
Need help wiring Honeywell Thermostat from White Rodgers mrx900 HVAC 5 06-06-2010 04:57 PM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Trane Aux heat modification tj1mcd HVAC 2 12-05-2009 08:24 PM
Making a blower work with a White Rodgers 50A55-405 Controller gegnerx HVAC 3 01-13-2009 04:58 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
