White Ridgers HSP-2000 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 01:43 PM   #1
Tinkerer's Avatar
White Rodgers HSP-2000
I just installed this humidifier on my new American Standard Heat Pump system. Everything seemed to go well and it fired up right away. The issue I have is that it never came back on after the first cycle and the house humidity is only at 34%. I unplugged the unit and plugged it back in and it came on again. Seems to stop after the first cycle. The only thing I noticed, during the install, is that the schematic called for a connection to "C" which I assumed was a common for the control board. There was no "C" connection on the terminal block so I measured everything and it seemed that W1, W2 & W3 were ground voltage so I used these. Could that be the problem or do I have an issue with the HSP? Thanks
Tinkerer is offline   Reply With Quote
Old 12-16-2010, 05:24 PM   #2
W's are not commons. Follow the transformer leads. One will go to R and the other is common.
Old 12-16-2010, 07:54 PM   #3
Tinkerer's Avatar
Thanks, works fine now. Out of curiosity, what are the W's for?
Old 12-16-2010, 09:54 PM   #4
W's are your back up heat terminals.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
black, white, white, black! bamaranch General DIY Discussions 5 07-04-2010 12:24 PM
Painting white martinigirl Painting 3 04-26-2009 06:24 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 07:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
