White Or Clean Dust - HVAC - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 06:54 PM   #1
white or clean dust
I'm helping a neighbor try and solve this issue that is plaguing her house.
About 2 months ago here in MN she started noticing white dust forming at an alarming rate. Her house is a rambler with a partially finished basement. There is one cold air return and one register down stairs and the dust seems to be isolated to the main level.
-She has had no construction
-No mechanical replacements.
-No new furniture or drapes installed.
She had her ducts cleaned about a month ago hoping that would help.
Here are a few photo's of the dust.
1989gta is offline   Reply With Quote
Old 09-05-2012, 07:34 PM   #2
Too Short? Cut it Again!
Weird it is making it past the filters.
Old 09-05-2012, 07:48 PM   #3
An old Tradesmen
Rewards Points: 6,462
Moved to HVAC forum.
Old 09-05-2012, 07:54 PM   #4
It was going through the blue filters so she switched to the pleated 3m, ill check in a week. I would expect to see some build up. Also its not sheet rock dust it has no smell or taste.
Old 09-05-2012, 08:19 PM   #5
I am experiencing the same problem with the exact same "dust".
I think I isolated my problem to leaky panned returns. The condition of my panned returns were not that great to begin with, but a duct cleaning company made them worse when the guys punched holes on the end caps to stick in their air compressor nozzles. Some end caps were crushed in so badly that the gap between it and the main return was more than 1" wide, resulting in sucking in dirty air from the un-finished side of my basement.
They also might have done a shoddy job of cleaning, especially if they did not use air whips or brushes, possibly loosening up caked dirt that is now breaking apart in the vent.
I would check for any large gaps in the return side and foil tape over them if necessary for now (I will be replacing my end caps with new ones and use mastic to seal them).
I would also run the blower fan at full blast for 24/7 for about a week while frequently changing the filter (I went through three 4" media filters in that time period).
Good luck
allthumbsdiy is offline   Reply With Quote
Old 09-06-2012, 07:11 AM   #6
I see that a lot on homes that had ducts cleaned. It's drywall dust from construction that was solid until the brushes loosened it up. The good news is it goes away in about a year.
Old 09-06-2012, 12:07 PM   #7
how
Rewards Points: 1,100
Marty's probably right on this but ask your neighbour if she had that dust problem before she had the ducts cleaned?
Also check if that same white powder is on the floor around the furnace. Some venting precipitate can get that bad on poorly designed chimney vents when combined with leaking return air/ filter slot covers/furnace blower doors/ etc.
how is online now   Reply With Quote
Old 09-06-2012, 06:05 PM   #8
The problem showed up a month before the duct cleaning, she had that done thinking it would help it did not. I'll have to look at the chimney.
glazing white builder grade cabinets - how to get this look? denemante Painting 1 11-04-2011 08:13 AM
spot clean white leatherette couch with smudges from clothing and belts jaidene Interior Decorating 2 11-02-2011 07:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 04:41 PM
Fine White Fiberous Dust Murpet General DIY Discussions 6 03-28-2005 02:27 PM
