-   -   whirring noise return duct (http://www.diychatroom.com/f17/whirring-noise-return-duct-42268/)
HPHP 04-11-2009 06:11 PM
I have Trane air handler Model # 4tee3f40b1000aa that makes a high pitch whirring noise and is most noticeable at the 80% speed. When the Dealer came out he said the whirring noise is beacause the return duct is not supplying enough air. What would you recommend to solve this problem?
kenmac 04-11-2009 06:15 PM
if the return was too small .. he should have increased the size or added return when he installed the furnace..Is the filter clean ?? Remove your filter & see if it makes the noise
HPHP 04-11-2009 06:21 PM
When you remove the filter or take off the air return grille the whirring noise stops.
kenmac 04-11-2009 06:25 PM
It needs more air
HPHP 04-11-2009 06:29 PM
How do I make that happen? Can I just change to a grille that allows more air to the return duct?
kenmac 04-11-2009 06:32 PM
add a return or enlarge the 1 you have... Again , If the installer told you it was too small.. Why didn't he enlarge it or add to it when he installed the unit ?
HPHP 04-11-2009 06:42 PM
The installer did not tell me the air return was too small. I called and complained about the whirring noise and they sent out a technician who said the air return duct was not getting enough air. The technican recommend adding a larger grille. I am waiting for installers manger to give me a call about solution to the problem. Thanks for the information.
HPHP 04-18-2009 09:20 AM
Hi. I had the dealer out and he cut out a whole in the box the air handler is mounted on and then put a grill there. They described this as adding a return. Was this a reasonable solution?
mjbxx 04-18-2009 09:52 AM
Did the hole rid the whirring noise? What size hole was made? This does not sound like a proper fix to the noise.­­ Just my 2 worth.
key1cc 04-18-2009 10:06 AM
Where is the air handler located? Is it in a conditioned area?
Key1
HPHP 04-18-2009 02:30 PM
The hole is about 6x14 and did get rid of the whirring noise. The air handler is in a closet off the hallway.
mjbxx 04-18-2009 04:23 PM
Is the system a heat pump? Is the new return for just the closet area? How big is the closet? And does it have a louvered door to allow air in from outside the closet area?
C44 04-20-2009 06:43 PM
I am a homeowner who has worried a lot about having enough return. While your new return is not elegant, I think it may be OK. Returns are a lot less rocket science than other parts of HVAC.
