Whirlpool/Tempstar Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 07:09 AM   #1
Whirlpool/Tempstar furnace
Have a Whirlpool/tempstar Model NVGG125BF01 having intermittant start problems I can turn power on and off several times and furnace will start or tap on gas valve assy and it will work for a day or so do I need to replace entire assy or can I get repair parts for assy!!
sgedmison is offline   Reply With Quote
Old 11-23-2011, 07:44 AM   #2
How old is this unit? from the very brief description that you gave it sounds like it may be a bad electrical connection, Or a lock out issue such as a dirty flame sensor. A picture is worth a thousand words.... can you post a couple of this unit with its doors off?
harleyrider is offline   Reply With Quote
Old 11-23-2011, 09:51 PM   #3
Rewards Points: 582
does this unit have hot surface smartvalve assy....if it does wiggle the ignitor lead where it connects on gas valve....HAD A CONNECTOR PROBLEM solution replaced gas valve...
Old 11-24-2011, 10:09 PM   #4
Rewards Points: 616
yep order a new gas valve or you will be cold soon
carmon is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
