Where's The Water Go? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2008, 04:28 PM   #1
Where's the water go?
I have a hot water heating system that isn't working very well. When I started it up this year I bled the air out twice. Now the system is low on water. Where does it go?
severancem is offline   Reply With Quote
Old 12-13-2008, 04:39 PM   #2
Rewards Points: 1,548
Add water to bring the level up for proper operation. Then if the water level starts to drop, check the system, every inch of piping, for a leak. For piping inside walls and ceilings, you'll have to rely on water stains to point out leaks.
Does the furnace have a firebox (combustion chamber) that is quite open and has an access door? Let the furnace cool down and take a look inside to check for moisture that could suggest a leak inside.
Old 12-13-2008, 04:53 PM   #3
Thanks for the speedy reply. I just filled it up so we'll see what happens. I have access to all the piping and haven't found any evidence of a leak but I'll keep my eye out. Thanks again.
Old 12-14-2008, 06:50 PM   #4
tk03's Avatar
Rewards Points: 150
Is this a steam or hot water system?
tk03 is offline   Reply With Quote
Old 12-15-2008, 08:32 PM   #5
It's a hot water system.
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
