-   -   Where's the water go? (http://www.diychatroom.com/f17/wheres-water-go-33686/)
severancem 12-13-2008 04:28 PM
I have a hot water heating system that isn't working very well. When I started it up this year I bled the air out twice. Now the system is low on water. Where does it go?
AllanJ 12-13-2008 04:39 PM
Add water to bring the level up for proper operation. Then if the water level starts to drop, check the system, every inch of piping, for a leak. For piping inside walls and ceilings, you'll have to rely on water stains to point out leaks.
Does the furnace have a firebox (combustion chamber) that is quite open and has an access door? Let the furnace cool down and take a look inside to check for moisture that could suggest a leak inside.
severancem 12-13-2008 04:53 PM
Thanks for the speedy reply. I just filled it up so we'll see what happens. I have access to all the piping and haven't found any evidence of a leak but I'll keep my eye out. Thanks again.
tk03 12-14-2008 06:50 PM
Is this a steam or hot water system?
severancem 12-15-2008 08:32 PM
It's a hot water system.
