Where To Site A Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 08:19 AM   #1
Send a message via Skype™ to johnsiddle
Where to site a heat pump
OK I know this is my second post today but I am all fired up...
If I bought a Air Heat Pump, given the UK weather is not that good summer or winter, where would be the best place to site the unit, in the garage where in winter the air temperature is warmer but cooler in summer or outside in the open air where in summer it will get some direct sun but in winter will get covered in frost, snow and rain, oh and a little sun.
Regards John
johnsiddle is offline   Reply With Quote
Old 11-27-2010, 09:24 AM   #2
Rewards Points: 392
Regards John
I put my heat pump on the north side of my house where it will always be shaded from the sun by the house. In the summer there is slightly cooler air on that side of the house. In the winter there is no sun so it doesn't matter.
I made the decision based on what would look the best and what would be farthest away from my bedroom so you don't hear the compressor.. The unit was so quiet anyway so it didn't really matter..
zootjeff is offline   Reply With Quote
Old 11-27-2010, 09:42 AM   #3
Thanks mate, I also thought that maybe to site it in the loft area might be a good place it would then recycle any heat that escaped from the rooms below in the winter and in the summer the roof gets quite hot (when the sun is shining).
Or even on a bracket above the flat roof garage but it would really be open to the elements.
Regards John
Old 11-27-2010, 10:26 AM   #4
HVAC Tech/Owner
Rewards Points: 604
It's supposed to be exposed to the elements. If you put it in the garage, your garage will become un-bearably hot in the summer. It is made to exchange heat to the outdoors.
Technow is offline   Reply With Quote
Old 11-27-2010, 11:13 AM   #5
Thanks for your reply, However the garage is not used for a car and we rarely have enough sun in the UK to warrant the use of an A/C (air cooler)
I take your point tho that in the winter the garage will get very cold.
So I guess on a bracket above the garage roof looks good, it will get some winter sun (when we get any) and in the summer the sun is there until 1.30 or so (also when we get any).
The garage wall will make a good entry point into the house also my Solar storage tank is in the garage so I could plumb into that and heat the water when solar is not so good.
thanks for your input.
John
Old 11-27-2010, 06:58 PM   #6
An old Tradesmen
Rewards Points: 7,782
Sunshine on the heat pump won't help it heat your house. The amount of air it moves will render useless any radiant heat that it would have gotten.
Old 11-27-2010, 07:43 PM   #7
I thought if the sun was playing on or around it then the air temp in that area would be higher.
So really its a case of fit where it is most convenient.
Thanks guy's
John
Old 11-27-2010, 07:46 PM   #8
An old Tradesmen
Unless your setting it in a parking lot. No benefit from solar gain/radiant heat.
The Following User Says Thank You to beenthere For This Useful Post:
johnsiddle (11-27-2010)
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 12:54 PM
Installing natural gas furnace in place of heat pump, please help KlamathMog HVAC 17 10-20-2009 01:55 PM
Heat Pump czars HVAC 3 02-06-2009 08:49 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
