Where To Put A Thermal Sensor? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 09:58 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Where to put a thermal sensor?
I bought a USB relay/sensor controller which I will be incorporating into a custom web based thermostat that I will code. The sensor looks like a transistor, and it also needs a resistor to run. I soldered it on a small piece of plastic so it's a single contained unit. (posted pic)
What I'm wondering is how do I go about placing this somewhere so it looks half decent? Can I just put it in the return vent, at the grille? I'm just afraid I might get bad readings there though.
It almost needs to be exposed and at eye level where I wont be reading the lower cooler temp nor the higher hotter temp, but the middle. Just not sure how to go about doing that without having an actual circuit board on my wall. Or how would I make some kind of casing around it? As something really primitive I'm thinking of maybe mounting it on the wall bare and just have a picture in front of it. Or some other decoration perhaps. Whatever I do, the sensor obviously can't be completely covered or it wont get the proper readings.
I was thinking of just placing it right behind where the thermostat is, but it does not look like there would be clearance for the thermostat's circuit board when I clip the thermostat back on. I still want to keep it as a backup, it will be connected to the heat terminals only.
I have a few ideas in mind, but just wondering if anyone has any other ideas I may have not thought of.
Old 01-18-2012, 10:17 PM   #2
There are tons of cheap battery devices sold at places like radio shack that could serve as your case. I'm thinking of one of those lights that are about 5 inches in diameter and you can stick them up anywhere, you just push on the whole unit to turn it on or off. There's got to be some inconspicuous device you can re-purpose that blends in. Alarm sensors are about the same size but the chance of you finding an alarm sensor case on the cheap is slight.
Bobeht is offline   Reply With Quote
Old 01-18-2012, 10:37 PM   #3
Wire Chewer
Rewards Points: 46
You know what, I just got an idea that might work perfect, it never occured to me till now. I have a clock right over my TV, and there is 3 wall plate jacks below it. They would serve as a point to put my hand so I can stick the wire through the hole. That would be my main floor sensor, and should match more or less with the thermostat's reading.
Good idea about those lights, I may look at using one of those. Those battery boxes may work too. I can then paint it the same color as the wall (I still have left over paint for most, if all the rooms)
Old 01-18-2012, 11:44 PM   #4
televisions throw off alot of heat
harleyrider is offline   Reply With Quote
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 01:36 PM
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
Installing 3-way occupancy sensor westbank Electrical 6 05-04-2010 06:08 PM
Wiring Motion Sensor Electronic Lighting Switch consultant Electrical 2 03-07-2010 08:19 PM
Occupancy Sensor: Did I wire it correctly? kohaiut Electrical 7 01-14-2009 11:13 PM
