Old 02-11-2009, 11:32 PM   #1
where to position the main trunk?
in my basement, there are two main beams. i want to run the main trunk under one of these. when the branches cross the other beam, should i use two 45 degree elbows to get the duct up between two joists?
would having the main trunk closer to one side of the basement so that the braches are approximatley twice as long on one side rather than the other be ok? (i have not done the duct calculation yet, waiting on blower specs)
how far can the pvc flues on the newer furnaces run horizontaly in the basement before exiting the house?
how do i cross under the return main trunk with the supply braches?
drewhart is offline   Reply With Quote
Old 02-12-2009, 05:17 AM   #2
An old Tradesmen
Best to use 45's.
You can have one side loner then the other.
The allowable vent length varies with the furnace brand and model.
Old 02-12-2009, 09:35 AM   #3
will there be a manual with all this stuff in it with the furnace? do they the all give figures for the external static pressure?
Old 02-12-2009, 03:16 PM   #4
An old Tradesmen
The furnace manual, will give you the CFM at different static pressures.
No other duct instructions though.
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
Hello! My name is Kevin Winsley. I’m with Offshore Sailing School and today on Expert Village I’m going to talk you through the different points of sail, mostly about sailing around in sailboats. The first thing to know about sailboats is we... Read More »
Hi this is Drew Finn for expertvillage.com we are going to talk about cleaning and maintaining a deck. This video is presented by Black Dog Video and you can visit us on the web on blackdogvideo.biz. When we are checking underneath we want to make sure... Read More »
I'm Melina and welcome to Expert Village. Today, I am going to show you how to make screen print design on a t-shirt. The first things that you are going to need a regular piece of paper, where you?re going to draw a design. You?re going to need waxy... Read More »
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Main Service Disconnects rwlawrence Electrical 5 11-04-2008 11:46 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
