Where I Can Buy A Thermal Protection Device? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 03:20 PM   #1
where i can buy a thermal protection device?
We have a Trane furnace xe 80 which stopped working now. It it the thermal protection device which needs to be replace. Where I can buy this part, and how much it generally cost? Very much appreciate your advice.
ying is offline   Reply With Quote
Old 12-15-2012, 03:43 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,730
Ayuh,.... Is it the type that cuts the power, or the fuel,..??
Donno if the big box stores carry 'em, or not,...
If it's the electrical cut-off, 'bout any commercial Hvac supplier, or Electrical supplier oughta have 'em, in stock,...
If the fuel shut-off, the Hvac supply house would be the place to look...
The Following User Says Thank You to Bondo For This Useful Post:
ying (12-16-2012)
Old 12-15-2012, 03:57 PM   #3
how
Rewards Points: 1,104
How do you know it's not working?
Is it a main limit or a roll out switch?
An HVAC supply house that carrys Trane might be a starting point.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ying (12-16-2012)
Old 12-15-2012, 04:18 PM   #4
Rewards Points: 1,300
Could you post a picture of it? There are several types of thermal cutouts on the market. Some are even resettable
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
ying (12-16-2012)
Old 12-15-2012, 05:09 PM   #5
Roofmaster
Rewards Points: 2,210
POST A PICTURE FOR GOODNESS SAKES!
Old 12-15-2012, 05:13 PM   #6
An old Tradesmen
Rewards Points: 8,200
Find out what cause it to go bad. thermal limits on a furnace are safeties, not operating limits. So there is a problem that caused it to go out.
The Following User Says Thank You to beenthere For This Useful Post:
ying (12-16-2012)
Old 12-16-2012, 11:02 PM   #7
The heating system stopped working. Then checked and the diagnosis box shows "thermal protection device needs to be replaced".
Old 12-17-2012, 04:12 AM   #8
An old Tradesmen
The cause of its failure needs to be found and corrected.
How does grounding work? scyarch Electrical 44 06-12-2012 04:59 PM
thermal release device gmackey Plumbing 4 01-07-2012 07:42 AM
GE Gas Water Heater Thermal Release Device BfairOK Plumbing 0 12-10-2011 09:36 PM
What kind of surge protector to get for these items baby327nd Electrical 27 10-06-2011 03:35 PM
Electrical Baseboard Thermal Protection Blade_316 Electrical 5 10-22-2009 05:51 AM
