Where To Get It - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 03:45 PM   #1
Exclamation
Where to get it
Does anyone have a website that you can purchase the flexible metal ducting from? There was a shop close to me ( ezlink) that manufactured some good quality insulated metal ducting THEY ARE OUT OF BUSINESS!!! Now I cannot seem to find a good quality metal flexible insulated product from 4" to 12"......
nzvlnr is offline   Reply With Quote
Old 08-24-2011, 06:47 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Never heard of metal flex but here's flex.
http://www.quietflex.com/
Doc Holliday is offline   Reply With Quote
Old 08-25-2011, 09:20 AM   #3
Where do you get it
Look at home depot, lowes...they have metal flex tubing, it is not insulated......The ezlink stuff was great. My friend ran new ducting in the lower level of his house 2 years ago.Now I was going to do it and they are out of business.......Its either flex or metal ducting...
Old 08-25-2011, 09:32 AM   #4
fabrk8r
fabrk8r's Avatar
We used to install insulated aluminum flex duct. It's all we used for years. It's a lot more expensive than plastic wiremold flex and it causes a lot of air turbulance, but it's really tough stuff and very durable.
We don't use it anymore because all the specs call for wiremold flex now. When we did buy it it was from a company out of TX. It came in 8' lengths and had fiberglass insulation wrapped with a black plastic sleeve. I believe it had an R-4.5 R-value.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-25-2011, 10:21 AM   #5
where to get it
Great, any idea where to be able to get the stuff now? I cannot find it anywhere?
2nd choice is to go with metal ducting, but where do I get the insulated stuff? Do they make that? CAUSE BUYING THE RIGID PIPE AND ASSEMBLING , SEALING THEN INSULATTING IT....wow big job..
Old 08-25-2011, 10:53 AM   #6
fabrk8r
fabrk8r's Avatar
McMaster -Carr sells aluminum flex duct w/no insulation.
We buy fiberglass duct sleeve from our supplier when we need to insulate hard pipe.
Check to see if you have any insulating contractors in your area. They may be able to find what you need. Check local commercial sheet metal shops too.
