Where Is The Filter On This Trane? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2013, 02:17 PM   #1
Lord of Slums
Rewards Points: 1,974
Where is the filter on this trane?
Point me in the right direction on a filter change
Where is the filter on this trane?-hpim2109.jpg   Where is the filter on this trane?-hpim2107.jpg   Where is the filter on this trane?-hpim2108.jpg   Where is the filter on this trane?-hpim2110.jpg
mj12 is offline   Reply With Quote
Old 06-05-2013, 02:50 PM   #2
MarginallyQualified
Rewards Points: 2,464
Go back inside and take some pictures of the blower.
The filter will be on the intake side of it.
Old 06-05-2013, 05:10 PM   #3
An old Tradesmen
Rewards Points: 6,470
Second pic, the panel with the hood on it, as I recall.
Old 06-05-2013, 05:57 PM   #4
This is a packed unit. The blower is inside the unit pictured.
The filter should be on a grille indoors. Either that, or as beenthere said, it will be behind that panel with the hood on it.
ModelAFan is offline   Reply With Quote
Old 06-05-2013, 06:24 PM   #5
MarginallyQualified
Yep. I didn't read the label or notice the gas pipe until after BT posted.
I mistook it for a condensing unit
Old 06-05-2013, 06:34 PM   #6
You shouldn't even have to read the label to see that it's a packaged unit unless it's a commercial model or older model that is larger.
Old 06-05-2013, 07:43 PM   #7
MarginallyQualified
You shouldn't even have to read the label..
If I were an HVAC guy you would have a good point!
All I've ever done with them is wire 'em up.
(then I'll read the labels)
Old 06-05-2013, 07:51 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
Behind the panel with the hood. The hood is for fresh air makeup and U can see the drain line from the evap coil which is close behind the door after the filter.
Old 06-06-2013, 05:49 PM   #9
Lord of Slums
Learn something new everyday. Yeah, it was behind the hood, drain pipe held the cover on, but a little force and it opened. Filter was a 20x20x1. They are about a dollar each. Looked at the one for 20 dollars, then settled on the 97 cent one
Old 06-06-2013, 06:10 PM   #10
Hvac Pro
yuri's Avatar
use the 3-4 dollar Merv 7 or 8 from HDepot. It will keep the coil and blower clean better. You get what you pay for an those $1 are next to worthless IMO, if you can read the newspaper thru it then dust can get thru it easily.
trane xr90 3 blinking red lights after filter change murphyje HVAC 1 10-30-2012 04:33 PM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Trane XE80 furnace, best filter to buy dinosaur1 HVAC 33 02-11-2012 12:59 PM
Trane Filter Cover Question spyder24 HVAC 2 04-04-2010 08:42 AM
Trane whole house filter - Is it worth the money? Leoskee HVAC 4 03-25-2010 01:17 PM
