Where To Drill 4" Vent In Basement Wall? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 08:56 AM   #1
Where to drill 4" vent in basement wall?
Does anyone know what the code says regarding where one can drill a 4" hole to exhaust through a basement wall? I've got two options; either option would cause the hole to exhaust about 2.5'-3' above the ground outside.
1) Bore 4" hole through 12" thick foundation wall
2) Bore 4" hole through an 8" rim joist (I'm assuming it is a single 8x2" rim joist, and not two 8x2" joists laminated together)
Would prefer going option 2 - easier to drill and don't need to have a bulkhead to hide the exhaust (it can be hidden between floor joists), however, I don't know if code allows me to cut out half the rim joist to run an exhaust outside.
Thanks!
Eric
benze is offline   Reply With Quote
Old 09-20-2010, 06:39 PM   #2
Option # 2. As long as this is pvc for a 90% furnace
hvaclover is offline   Reply With Quote
Old 09-20-2010, 07:25 PM   #3
Actually, not even. Need to make an exhaust for a dryer and an exhaust for a bathroom vent. Planning to use galvanized HVAC tubing.
Thx,
Eric
Old 09-20-2010, 07:43 PM   #4
Your still good on option # 2.
Old 09-21-2010, 06:52 PM   #5
Rewards Points: 494
Wink
Took a look at my installation. You probably know this but for safety I'll mention anyway. Pipe should be sloped/tilted downward towards furnace. Probably a 2 inch slope over every 10 foot run. That's so condensate runs back to furnace through pipe and to drain. Probably prevents both freezing and mold. Any condensate that makes it all the way to outside will fall to ground.
edit: Thought for furnace. Dryer doesn't matter.
diyorpay is offline   Reply With Quote
Old 09-21-2010, 07:04 PM   #6
1/4" per foot raise from furnace to termination.
Microwave with exhaust to vent down to basement and out vellefson HVAC 8 02-10-2010 02:11 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
Repainting wall in basement color advise Dionysus Interior Decorating 2 12-25-2008 07:17 PM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 10:26 AM
