Where To Drain Condensation From Hi-Efficiency Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 02:24 PM   #1
Where to drain condensation from Hi-Efficiency Furnace
Hello Guys and seasons greetings.
I have a question currently my Hi-Efficiency furnace condensation is pumped to the laundry room and drained into the floor drain. I am wondereing if that is correct, will there be any problems doing that.
I was thinking to relocate it to where my washer drains to, the washer is attached to a pee-trap which is attach to the septic pipes and then goes to city sewer.
Which method would be better (floor drain or septic pipes), hope I get all the terminologies correct, any feedback would be greatly appreciated.
Thanks,
Samantha
samantha.77 is offline   Reply With Quote
Old 12-28-2010, 02:40 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
You know Max
Max/makes no difference.
Old 12-28-2010, 02:47 PM   #3
I should mention that my house is 40 years old and the washer drain to the septic pipes (stack) which are made of cast iron, so I am wondering if it is safe to drain the furnace condensation there since it is slightly acidic. Or is it better to just drain into the floor drain??
Old 12-28-2010, 03:14 PM   #4
Hvac Pro
yuri's Avatar
We drain ours into the floor drain and plumbing stack only if we cannot get to the floor drain. Not acidic enough to cause a problem (acidic like orange juice). More work and hassle and expense to tap into the plumbing stack so I would leave it alone. Unless it is a trip hazard with the hose crossing the floor we use the floor drain.
Old 12-28-2010, 03:23 PM   #5
thanks yuri for the reply. Right now I have it draining to the floor drain in the laundry room but it does cross the floor and some-one can trip over over it.
I was going to remove it and drain it to the plumbing stack via the washing machine hook-up pipe, the washing machine pipe is a black plastic pipe with a p-trap that is tapped into the cast iron plumbing stack.
Can I do this?
samantha
Old 12-28-2010, 04:15 PM   #6
Hvac Pro
yuri's Avatar
Post a pic of the washer drain hookup. There is a black ABS 1 1/4 or 1 1/2 tee "Y" which you may be able to get at HDepot and put a bushing in it and then the hose from the pump. I don't like jamming the pump hose in beside the washer drain hose as it can get pinched/kinked /soap scum on it etc and burn out the pump. My installers use the tee "Y" fitting but you may need to get a plumber involved.
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Running condensation drain into house drain log_doc_rob HVAC 2 09-07-2009 10:46 AM
High efficiency furnace venting Mnrunner HVAC 14 01-18-2009 10:25 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
slope of ac drain and condensing furnace drain. hartkem HVAC 5 11-24-2008 09:38 AM
