Old 10-06-2010, 06:55 PM   #1
Where dose this gas line go?
Hi everyone, We just bought a house that has Gas and I want to add a cooktop. I was going to move the line from the range over but after looking at where the gas line goes it seems it runs into the wall cavety where the return air duct is and the range (electric) had no gas hook up near it. could this line run to the second floor or the attic? The furnace and hot water heater are in the basement so I'm puzzled. The house has a jacuzzi tub in the master could it go there. Any ideas would be great as I can't move the line if I can't find out where it goes. Thanks.
TheDerek is offline   Reply With Quote
Old 10-06-2010, 07:43 PM   #2
hvaclover's Avatar
Your question is not clear.
What exactly do you want to know.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 10-06-2010, 07:51 PM   #3
Is there anything that could be in the attic or the second floor that would have a gas line running to it? I have one that I can't find where it terminates. Laundry is in the basement as well and I have a fireplace but I can follow that line no problem.
Old 10-06-2010, 07:58 PM   #4
hvaclover's Avatar
Gas appliances of some type. If it's an old house it may have supplied a space heater or a wall furnace.
Can you see where it comes off the main gas line in the basement?
Old 10-06-2010, 08:23 PM   #5
its a 6 year old house and the line is the yellow flex line which comes off of a manifold where the furnace, water heater and fire place come off of.
would they run a line to the kitchen and close it up in the wall since the range was electric?
Old 10-06-2010, 08:36 PM   #6
hvaclover's Avatar
can't answer that for sure. But if it's just a short piece than I would say more than likely.
Old 10-06-2010, 10:28 PM   #7
30 year tech
hvac122's Avatar
Could it go outside for a gas grill? No way to know for sure without seeing and possibly taking down some drywall.
hvac122 is offline   Reply With Quote
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 11:07 PM
Mutiple phone line needs an answering machine Densplace Electrical 5 04-04-2008 11:35 PM
