Where Could I Get Something Like This Powered Baffle. - HVAC - DIY Chatroom Home Improvement Forum
Old 04-01-2010, 10:46 AM   #1
Rewards Points: 101
Where could I get something like this powered baffle.
I could use a tip or link to a site or supplier of electrically powered baffle or louvre system to put on a regular 4" or so vent I want to put through ends of my crawl space. I have space to cut only about a 6" high vent hole/grill/frame in the perimeter wall above my foundation wall and I want to control these vents with a simple 110V AC circuit and switch or whatever low voltage they might come with.
All I could find was a pictureof something that would work from an Asian website.
Thanks for any tip on a supplier of powered louvre or baffle units, preferably already integrated actuator and baffle ..or if I should just be looking for an actuator and attach it to my own baffle let me know,.
Thanks.
Hossenfeffer is offline   Reply With Quote
Old 04-01-2010, 03:44 PM   #2
An old Tradesmen
Rewards Points: 8,204
You might have a problem finding a 4" motorized damper.
5" is the smallest common size made.
Old 04-02-2010, 11:40 AM   #3
Rewards Points: 101
Oh, that's fine. I wll take anything of any duct shape or size that I can get to fit in the 8" or so space of foundation frame wall above the cement foundation wall......any shape or size that could be controlled by a motorized baffle will do.
Still grateful for any tips and links to suppliers.
Old 04-02-2010, 01:57 PM   #4
Home Air Direct's Avatar
If you are unable to find locally or a recommendation is not made, you are welcome to contact me and I can help hook you up. I am not supposed to self promote here and do advise that you wait for other responses.
Good Luck
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 04-02-2010, 04:11 PM   #5
An old Tradesmen
A direct over the internet place is as good as any place to get one.
Old 04-02-2010, 11:33 PM   #6
Hossenfeffer......Love the Screen Name
Hope this helps.
http://www.homeairdirect.com/store/i...76081a5dd8f0ca
Good Luck
(thanks Beenthere)
Old 04-05-2010, 10:40 AM   #7
Rewards Points: 101
Hey, that is great!
Love these forums.
I am still calling around this area for something similar bur now I know that they are obtainable and I may go for a cross country shipment if necess.
Thanks a bunch.
(don't know why, by my emailer dumped your message into my spam folder and I missed it for a while)
Thanks also beenthere....bet you are right.
Powered painting equipment cellophane Painting 8 10-05-2009 02:38 PM
Gable fan? Powered roof vent? idahojoec Roofing/Siding 2 07-25-2009 02:06 PM
replacing the baffle trim only on my recessed lights pwaxman Electrical 3 01-25-2009 05:59 PM
Non-Gas powered mowers. Experience? Thoughts? IckesTheSane Landscaping & Lawn Care 3 12-03-2008 01:04 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
