Where Can I Order Motor For Drum Humidifier? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 08:30 AM   #1
Where can I order motor for drum humidifier?
Gar Furance: Rheem Criterion installed 1993.
Problem: Motor for drum humidifier stops running after sponge gets wet
Drum humidifier has stopped delivering moisture for long time due to water pipe for it leaks. The motor was running fine when sponge was dry. I fixed pipe leaking problem but found motor stops running if drum sponge gets wet, which probably increases drum weight that motor can't offer enough power to keep it running.
I have two questions:
1. Where can I order drum humidifier motor? I am going to replace it.
2. Does this motor keep running for 24/7? I found the power for this motor is supplied by a power transformer that connects 110V wire before control broad. No matter furnace was on or off, it kept running all the time before.
Thanks for any input.
marion60 is offline   Reply With Quote
Humidifier Wiring to HAi Omnistat cipherman HVAC 10 11-09-2014 12:34 AM
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 04:26 PM
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 09:10 AM
Armstrong Furnace and Aprilaire humidifier wont shut off! HELP! scott0949 HVAC 8 12-09-2010 06:30 PM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 07:42 PM
