Old 11-02-2009, 03:00 PM   #1
Default Where can I buy a single relay?
So after looking at my circuit board it's very obvious that the relay is what got shot. $1.30. Problem is... you hafta buy in bulk. Does anyone know where I can get a single:
POTTER & BRUMFIELD T9AV1D12-22 22VDC RELAY
Thanks!
MichaelKB is offline   Reply With Quote
Old 11-02-2009, 03:27 PM   #2
Jack of All Trades...
TJ_in_IL's Avatar
E-Bay or Digi-Key, from a quick google search.
TJ_in_IL is offline   Reply With Quote
Old 11-02-2009, 03:27 PM   #3
Yoyizit's Avatar
Thanks!
http://www.mouser.com/ProductDetail/...qY6CWmcjPlU%3D
Also try Hosfelt, Marlin Jones, Allelectronics, Allied, Jameco.
You can use any relay with a 24v coil but the coil impedance/current needs to be as low or lower than this relay. 1w @ 22v = 45 mA. If the coil runs on DC the coil resistance is ~490 ohms.
The 30A contact rating probably needs to be for a motor load.
Old 11-02-2009, 03:29 PM   #4
Thanks! Bought it!
More On This Topic
What is the relay game in improv classes? Learn how to play improv games in this free video on theatre acting. Read More »
How to use a relay box to run LED lights in this free home maintenance video. Read More »
Learn some more great tips on how to use a relay box to run LED lights in this free home maintenance video. Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Need a relay for off peak heat BorisMD Electrical 16 09-13-2009 07:25 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 05:46 PM
Current sensing relay and general furnace?? Master Brian HVAC 0 04-28-2009 01:18 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 03:11 AM
newbie...relay problems jfabes Electrical 11 05-06-2008 06:48 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
