Where To Buy Replacement Condenser Fan? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 10:41 PM   #1
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Where to buy replacement condenser fan?
The fan on top of my outside unit is dying, it will run for 30-45 minutes but then will seize up and I have to turn the system off. The system blows cold, even when the fan is seized up; obviously, I have no desire to run it that way though. So I only power it up when I go to bed and then I shut it off when I audibly hear the fan seize, that gets my room temp down to 85 or so.
I am comfortable replacing this fan myself, but I haven't the slightest idea where I should go to get a new one. The outside unit is a Heil Max Performance 14 and it was installed in 2004.
brons2 is offline   Reply With Quote
Old 07-08-2011, 11:08 PM   #2
JJboy's Avatar
http://www.johnstonesupply.com/
http://www.grainger.com/
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-09-2011, 07:58 AM   #3
biggles's Avatar
get an idea of pricing here or order it..does the motor free wheel at all in either direction and brake hard any grinding noises...WD40 down the shaft for now till you can change it.... http://www.bestbuyheatingandairconditioning.com/ you need the actual numbers off the motor itself forget the unit info just the model and serial with brand incase you need to cross reference....Grainger has a tech help line to match it up NOTE get a new CAP with the new motor
Old 07-09-2011, 11:14 AM   #4
E-lec-tri-city
Rewards Points: 150
Yea definitely a lot of grinding noises when it's running. When the grinding noises stop, I know it has seized up again and I turn off the system.
Old 07-09-2011, 04:03 PM   #5
biggles's Avatar
bearing are shot if you get the slightest free wheel grinding
Old 07-09-2011, 09:14 PM   #6
E-lec-tri-city
Rewards Points: 150
I have separated the fan from the rest of the unit.
Emerson Model K55HXHEB-8584
HP 1/4
R.P.M 840/2SPD
HZ 60
AMP 1.5
PH 1
PT NO HQ1086397EM
MFG. NO. G02 C
INS CL B
AIR OVER CONT
FRAME 48Y
Old 07-09-2011, 09:48 PM   #7
An old Tradesmen
Rewards Points: 8,202
Thats probably going to be an OEM motor only. So you'll need to go to the local ICP/Tempstar/Heil distributor or dealer to get it.
Old 07-09-2011, 10:29 PM   #8
E-lec-tri-city
Rewards Points: 150
One of the links above quoted this universal replacement:
http://www.bestbuyheatingandaircondi...ode=MOT1086397
that being said it's hella expensive!
Grainger.com has a number of units with similar specs. I imagine the most critical component is not to go over the current rated amp draw?
http://www.grainger.com/Grainger/AO-...CW5?Pid=search
that one looks almost identical, only the shaft is longer than on the current motor.
Old 07-09-2011, 11:59 PM   #9
E-lec-tri-city
Rewards Points: 150
On a side note, the shaft has at least half an inch of play in it, I'm sure that it's not supposed to have quite that much!
Old 07-10-2011, 12:08 AM   #10
JJboy's Avatar
You always can cut the extra shaft. But 2" extra that's ok.
Old 07-10-2011, 04:17 AM   #11
An old Tradesmen
The Grainger motor is a single speed motor, 1075 RPM, too high to be used.
The other motor is a 840 RPM, but doesn't list if its a single or 2 speed.
The OEM motor is probably cheaper then the bestbuy motor.
Old 07-10-2011, 10:34 AM   #12
Rewards Points: 1,770
Might try this site:
http://www.usmotors.com/default_ecatalog.htm
bob22 is offline   Reply With Quote
Old 07-15-2011, 10:07 PM   #13
E-lec-tri-city
Rewards Points: 150
Thank you to JJboy, he met me at Johnstone Supply today and helped me get a replacement motor. You have to be a registered HVAC technician to purchase there and he helped me out. Got another Emerson motor and the capacitor to go along with that particular motor. Slightly different than the old one but it's working great.
I got it to work on the first try*
(*blowing the wrong direction haha)
The fan is reversible, so I took the top of the unit back off and put yellow to orange and orange to yellow and now it spins the correct direction.
The unit is much quieter now, I guess that old motor was having issues long before it started seizing, I guess it just worked well enough to make one assume nothing was wrong. It has a scroll compressor which I guess is supposed to be quieter in the first place. I cannot hear the outside unit running now while I am inside the house and I am extremely happy about that
Yay for DIY AC repair!!
Any ideas on a replacement condenser fan motor? 52Caddy HVAC 1 06-08-2011 09:30 PM
fan condenser motor replacement htrueblue33 HVAC 1 02-06-2011 03:06 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 01:54 PM
condenser fan replacement todthebod HVAC 4 02-21-2010 11:22 AM
Condenser Fan Replacement Help jackofonetrade HVAC 20 07-13-2009 08:14 PM
