Where to Buy Concord Furnace Parts
Hi, I'm new to the forum and am just wanting to get information on where to buy parts for a Concord furnace, I know they're bottom end a a POS but that's what the builder put in my house, if I have to call a technician I am just going to replace the damn thing. Anyway, through Justask.com I have found out that I need a circuit board and a pressure switch the problem is finding the pressure switch, any HVAC place close to me that can get it in won't sell it to me unless they come and install it :furious: and I can't find the pressure switch online. The issue with the furnace if you're wondering is that it will kick out shortly after start-up (within a minute) and start clicking continually.
It is a Concord CG90UB050D12B-1A, I know they're owned by Lennox and share parts with Armstrong and were owned by Allied Air. If anyone has any suggestions I would appreciate it. Thanks. |
What you are describing does not sound like a pressure switch or a circuit board to me. Other people posting here are having what sounds like the same problem you are having. Please look at the responses on concord furnaces. I posted several. If your furnace goes through the entire ignition sequence, starts up and runs fine, then cuts out, I really suspect a problem in your condensate evacuation system, or loss of draft from the inducer, caused by condensate build up. Can you post a picture of your furnace with the front panels off so we can see the design?
I am nowhere near as good as some of the guys on here like Doc, Yuri, Been there, etc. and they might be able to help. Sometimes a greenhorn like me hits on something out of the ordinary because we dont know any better. If your furnace has that condensate line that runs uphill to the inducer from the secondary HE, to me it flies in the face of logic. I would change it. |
Thanks for your info, I uploaded this video to youtube:
http://www.youtube.com/watch?v=r-b29zZH-mM I used justask.com and one of the HVAC specialists said the control board but if someone else has other ideas for me to try first I would love to hear them! :) I'll do some searching under Concord on here. |
If it ends up where you do need parts check out Pex Supply. Nicole is great. Great prices, and faster shipping than you can believe. I just looked at the video. OK so what was his final solution? The video ended before he said what was happening?
Never mind I see that is your video DUH.
I just watched your video again and I bet your flame rollout sensor is kicking your furnace off. you should not have that wayward flame all along the crossover tube. Have you had the air into your jets adjusted? Is your incoming and outgoing air intake and exhaust clear? Take it off and blow your leaf blower through it .
Thanks, I made sure the intake/exhaust was clear, I guess I could call a service guy to come adjust the flame and tell me what's really wrong but then I'm gonna be pissed haha.
Why would the LED indicator say pressure switch closed if its a different sensor? just asking because I know nothing about furnaces... I've never had one break before. |
At 2 years old, all parts should still be under warranty.
I'd clean the trap before I got any parts. |
Yeah, Take the trap off, and really clean the heck out of it. Run some bleach and water in it and let it set, purge, and do it again several times. It probably full of bugs and sludge.
is that a copper line going to the gas valve? sorry ive just never seen that before. is that system oil? we dont have any oil stuff around here so its interesting if that is oil.
No, its Natural Gas. All of the gas lines in my house are copper, first for me too, last house was all threaded pipe.
I thought the soft copper for gas had to be the stuff that's painted yellow so you don't confuse it with a water line. Anybody?
All of my water lines are pex, and much larger than the gas line so it would be hard to mix up :thumbsup:
Code, and code enforcement varies from area to area.
| All times are GMT -4. The time now is 05:24 AM. |
