Where To Buy A 120v - 24v Transformer Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 06:31 PM   #1
Where to buy a 120v - 24v transformer gas furnace
Looking to find a place that carries a 120v - 24v transformer for our gas furnace. Can you find them locally or do you have to order?
Patti King is offline   Reply With Quote
Old 10-06-2011, 06:51 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Try electronic stores or if you have a Grainger in your area, try there. Other than that hardware stores or hvac supply houses but actual supply houses may only sell to contractors. Only yesterday a member here found a transformer for $18 locally.
Usually there is a reason a transformer fails such as a short in a wire so you might want to physically check all high and low voltage wires in and around your condenser and furnace. Perhaps a wire nut fell off and the wire touched a cabinet.
Doc Holliday is offline   Reply With Quote
Old 10-06-2011, 06:54 PM   #3
Transformer HT01CN241
Old 10-06-2011, 07:20 PM   #4
biggles's Avatar
your local Grainger walk right in
Old 10-06-2011, 07:45 PM   #5
Houston204's Avatar
Rewards Points: 556
Radioshack and Frys also carry them.
Houston204 is offline   Reply With Quote
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
transformer and circuit brd in gas furnace gulley HVAC 5 11-21-2010 11:48 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 12:23 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
