When To Purge Air From Hot Water System - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2007, 04:53 PM   #1
When to purge air from hot water system
Hi;
I have a hot water heating system, and for some reason, I have always purged the air when the system is running and warm. Is this the correct time to purge, or should I do it when the system is not running and cold?
fw2007 is offline   Reply With Quote
Old 10-28-2007, 07:44 PM   #2
scotch on the rocks
hvactech's Avatar
the hotter the better.
hvactech is offline   Reply With Quote
Old 10-29-2007, 08:20 AM   #3
Thanks.
I Googled yesterday and found an article stating that the radiators should be warm, but that the pump should be off. I never had a problem with purging while the pump was running.
I eventually purged all of the air from the system. Two of the radiators which are the furthest from the furnace took some time, and as you said, the system needed to get hot.
FW
Old 11-29-2007, 04:33 PM   #4
Purging air from hot water heating system
How do you purge air from hot water heating system?
There are no vents on the 2nd floor base board radiators. Should I install vents? What type? Where?
worker is offline   Reply With Quote
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
New To Hot Water Home Heating System Midicat HVAC 2 10-14-2007 09:12 PM
Hot Water Heating System Estimate Cost ? helpless handyman HVAC 45 12-26-2006 10:59 AM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
