Old 10-11-2011, 05:01 PM   #1
when i turn to on, the pilot goes out
hi ,i have no problems with the pilot staying on but as soon as i turn to the on position it shuts off .does someone know y
thanks
omar4520 is offline   Reply With Quote
Old 10-11-2011, 05:04 PM   #2
JJboy's Avatar
Pilot on.....you see flame on the burner.....after that, shuts off?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-11-2011, 05:41 PM   #3
biggles's Avatar
make sure the pilot flames is surrounding the sensing rod and the capillay is tight into the gas valve.... if all is so you need a new thrmolcoupling in HD or LOWES measure the exsisting one 24"...36
Older Carrier 3-wire Pilot problem robsvsu HVAC 3 10-02-2011 07:11 PM
Heil Furnace Won't Turn On ada5011 HVAC 1 11-02-2010 08:29 PM
10 year old Carrier mid furnace with standing pilot BryanGregoire HVAC 3 10-01-2009 07:16 PM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 10:26 PM
