What's Wrong With My HVAC? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2009, 12:27 AM   #1
What's wrong with my HVAC?
Hi
Some background. I live in a fairly new condo and my Heater and AC was workingfine several months ago. I have a year old Rite Temp thermostat.
I turned my AC on for the first time and nothing turns on. The heat and fan does not turn on either and there is still power on the thermostat (it uses batteries). I switched the breakers off and on for my heater and AC and still nothing. What can possible be the reason? Any help would be appreciated as I just found out an HVAC serviceman is not cheap.
Thanks.
delusns is offline   Reply With Quote
Old 04-17-2009, 06:06 AM   #2
An old Tradesmen
Rewards Points: 7,400
Bad/blown air handler fue.
Bad control board.
Bad transformer.
Short low voltage wiring.
Bad thermostat.
Old 04-17-2009, 11:45 AM   #3
Bad control board.
Bad transformer.
Bad thermostat.
You left out bad mojo
Old 04-17-2009, 12:12 PM   #4
An old Tradesmen
Dang, I knew I was forgetting something. LOL
Old 04-17-2009, 01:06 PM   #5
HVAC / Plumbing
Originally Posted by delusns View Post
Hi
Thanks.
Someone has to pay for knowledge, etc Cheap work isn't good work,,, Good work isn't cheap
Seriously.. It could be many things.. Start with power 1 st
kenmac is offline   Reply With Quote
Old 04-18-2009, 04:23 PM   #6
Crazy, but lovable
flyboy2610's Avatar
Reminds me of a sign I saw once:
We can do it right.
We can do it fast.
We can do it cheap.
You get to pick two out of three.
If you want it fast and right, it won't be cheap.
If you want it fast and cheap, it won't be right.
If you want it cheap and right, it won't be fast.
What'll it be?
flyboy2610 is offline   Reply With Quote
Old 04-18-2009, 04:59 PM   #7
The 'stat calls for cooling.
The many sensors allow or inhibit cooling.
The control board listens to the 'stat and sensors and commands or inhibits cooling and air movement.
Start by turning the 'stat fan switch from "auto" to "on" and noting what happens, checking for blown fuses and measuring voltages inputted to and outputted from the control board.
You'll need a schematic and a cheapie voltmeter.
Figure on spending at least the morning, more if you short anything out.
You need to find the root cause of the problem, not a symptom of the root cause.
BTW, there is a contactor in the compressor housing that starts the compressor.
I saw an HVAC guy push on the contactor armature, and when he did the compressor kicked on, which told him that it was not a compressor AC power problem.
Turned out squirrels had chewed the control wiring feeding the outside compressor.
Be careful.
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
HVAC Upgrade Questions JonC HVAC 8 02-27-2009 05:04 PM
