What's The Best Way To Heat A 24x30 Room With Electric? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 05:19 PM   #1
What's the best way to heat a 24x30 room with electric?
I am just curious to find what the best way to heat a 24x30 room with electric. What would be the cheapest to run versus the cheapest to install.
I am in the midwest if that helps.
I have been looking into a heat pump and trying to figure out the proper size that I might need. Is there a better option?
Thanks!
indianaftw is offline   Reply With Quote
Old 02-22-2011, 05:40 PM   #2
You either install baseboard electric heat, or run duct work and install a heat pump. What's the room going to be used for? How many windows are there? Do you have the height to run your duct work? If it was me and the room wasn't going to be used a whole lot like a basement I would install baseboard and keep the stat down low and just turn it up when the room is in use. Good luck.
Hubcap626 is offline   Reply With Quote
Old 02-22-2011, 05:45 PM   #3
The room is going to be used for business storage / shipping location. So for 16-20 hours / day it would not be in use. But the items need to be somewhat climate controlled and when I'm in there, I would like to be warm enough to work (65 degrees or so).
There are two windows. One at each end. It is it's own building.
Pros Cons All Electric Home??? Property Virgin Electrical 31 01-20-2017 08:58 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
gas furnace vs 1 room electric heater Red Squirrel HVAC 11 10-17-2009 09:23 PM
advice on electric heat smartin114 HVAC 10 04-07-2009 11:43 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
