What Year Trane A/c Do I Have? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 01:25 PM   #1
what year trane a/c do i have?
My mom had a Trane a/c unit installed Aug. of 2008. Labor and all 4000.00. When she asked where the manual was, they told her it does not come with one.. how do we know she was sold a new one . This is the Model # 2TGB3F3OA
GENATAY is offline   Reply With Quote
Old 06-14-2009, 02:20 PM   #2
Home Air Direct's Avatar
The answer to your question lies in the Serial number. Below is some info that might help. Also, I think Plumber 101 is a Trane dude, he might be able to help better.
Good luck.
TRANE
Trane used alpha codes in their serial numbers to determine year of manufacture. They started this in 1987 with the letter B and skipped the letters I, O, Q, U, Z
In 2002 they started their serial numbers with the year it was built.
The first letter of the serial number gives the year of manufacture as follows:
9=2009 8=2008 7=2007 6=2006 5=2005 4=2004
3=2003 2=2002 Z=2001 R=2000 P=1999 N=1998
M=97 L=96 K=95 J=94 H=93 G=92 F=91 E=90
D=89 C=88 B=87 S=86 Y=85 X=84 W=83
U=82(seventh digit)
T=81(seventh digit)
O, A=80(seventh digit)
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-14-2009, 02:21 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Post serial number..please
Can not tell year by model number
Old 06-14-2009, 02:34 PM   #4
Rewards Points: 560
Double check the model number I am not finding anything with the number you provided
Every unit comes with a owners and intallation manaule
Old 06-14-2009, 03:05 PM   #5
what year is my trane a/c
Thank you for your quick response. Here is the serial # 8215LG36V
Old 06-14-2009, 03:29 PM   #6
Rewards Points: 560
The model number you provided is for the air handler not the actual a/c condenser.
From what I am seeing is that it was made the 21st week of 2008.
Below is a link to the Install and Owners manual
https://www.comfortsite.com/EBiz/Pro...LON=32-5039-05
https://www.comfortsite.com/EBiz/Pro...ON=18-GJ02D1-1
Old 06-14-2009, 03:42 PM   #7
Thank you Plumber101 for everything.. now to get them to give her a manual.
apparently they didn't sell her one big enough for 1500sq feet home, using a 2.5 ton a/c ...in SOUTH ALABAMA 30 MILES FROM THE BEACH..
Old 06-14-2009, 03:48 PM   #8
Rewards Points: 560
I posted links for the manuals .. just click on them and print
Why do you need the manual are you having problems?
Old 06-14-2009, 04:00 PM   #9
Size of my a/c
She's claiming it won't shut off setting at 78. 90degrees outside. The one she had before kept the house comfortable.The freon is perfect and all filters, no leaks.
Old 06-14-2009, 04:14 PM   #10
Rewards Points: 560
Measure the temp coming out of the supply register and return grill and post it
Old 06-14-2009, 04:30 PM   #11
OK. I'll be going to her house tomorrow, find someone w/ gauges. It is 80degrees in her home 93 outside. She set the thermostat at 73.
Old 06-14-2009, 05:40 PM   #12
An old Tradesmen
Rewards Points: 6,560
Make sure they have temp probes to measure air temps, and line temps.
Because pressures alone don't tell you anything.
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
Trane XL90 Annual Problems C63 HVAC 2 10-20-2008 06:01 AM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 01:16 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
