What Is Wrong With My AC? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 01:10 PM   #1
What is wrong with my AC?
I recently bought a house, which is about 9 years old. After moving in, I set the fan from AUTO to NO., but still the air blower keeps running almost all the time, no matter whether gas is burning or not. Very occasionally it stops when I set the room temperature to lower.
The AC is control by a system called Andover Home Controls. I found a text file on CD-ROM about this controller. Part of the file looks like below:
EnetCntrlrs
Object : INFINITY1
Type : Controller
NetworkId : 1
Model : 220
SerialNum : 60720
VersionNum : 2.16
EndObject
EndEnetCntrlrs
Dictionary : INFINITY1 : 1
'TYPE : NAME : HANDLE : DEFAULTMODE : BAUD
CommPort : InfinetPort : 6780 : Infinet : Baud19200
CommPort : UserPort : 6781 : AutoSet : Baud9600
'TYPE : NAME : HANDLE : PORT : SERIALNUM : INFINETID
InfinetCtlr : TCX843 : 7001 : 1 : 696847 : 1
InfinetCtlr : TCX867 : 7000 : 1 : 968202 : 2
User : ACC : 750
EndDictionary
Dictionary : INFINITY1 TCX843
Input : DAT : 3
Input : Filter.DP : 1
Input : OAT : 2
Output : Attic.SS : 4
Output : Breaker1 : 5
Output : Breaker2.Off : 6
Output : Sprinkler.Vlv1 : 7
Output : Sprinkler.Vlv2 : 8
Numeric : HowManyPushes : 12
Numeric : PushWaitTimer : 11
Numeric : xAttic.Stpnt : 15
Numeric : xKenna.ST : 14
Numeric : xLiteFlashRate : 19
Numeric : xMbdrm.ST : 9
Numeric : xSmartSensor : 16
Program : Transfer : 10
Program : AtticFanControl : 13
Program : AtticFanPBTimer : 17
Program : ChristmasLites : 18
EndDictionary
Dictionary : INFINITY1 TCX867
Input : Kenna.SH : 2
Input : Kenna.ST : 1
Input : Living.ST : 9
Input : MasterBedRm.ST : 3
Output : Attic.Speed : 8
Output : Clg : 5
Output : Fan : 7
Output : Htg : 6
Output : Humidifier : 4
Numeric : Attic.Stpnt : 33
Numeric : BackYardSelect : 36
Numeric : BeginCallForHeat : 31
Numeric : ClgStpt : 25
Numeric : DayMode : 20
Numeric : EnOvrdSelect : 37
Numeric : FanSelect : 26
Numeric : FrontYardSelect : 35
Numeric : HtgStpt : 18
Numeric : LCDDisplay : 13
Numeric : LiteFlashRate : 41
Numeric : NiteSB : 22
Numeric : OvrUnOcc : 23
Numeric : SH.Stpnt : 30
Numeric : ShowSprnklrNum : 34
Numeric : Sprnklr.1 : 39
Numeric : Sprnklr.2 : 40
Numeric : UnOccStpnt : 24
Numeric : xDAT : 16
Numeric : xFilterDP : 28
Numeric : xOAT : 14
Function : ResetSchedule : 43
Program : Htg.Control : 10
Program : Fan.Control : 11
Program : SpaceDisplay : 12
Program : Transfer : 15
Program : MainMenu : 17
Program : Variables : 19
Program : FanDisplay : 27
Program : HumidityControl : 29
Program : Clg.Control : 32
Program : SprinkleControl : 38
EndDictionary
Anyone has idea if the non-stopping blower is related to this controller? I also attached a diagram
hlee is offline   Reply With Quote
Old 03-15-2010, 02:43 PM   #2
An old Tradesmen
Rewards Points: 6,850
First. Turn the thermostat fan switch back to AUTO.
Then. Get a hold of who ever owned the house before you. And ask them for the operators manual for your automation system.
Or, you will have to call the manufacturer, or installing company, and ask them for all of its operating instructions.
Old 03-15-2010, 08:26 PM   #3
MXer
3 legged dog's Avatar
I dont think andover is still around. Is there no display screen? If not then the previous owner had it ran to a PC. May be simpler to get a nice Tstat and sprinkler timer.
As far as the fan, its sounds like it's set up as a stage of heat or cool.
3 legged dog is offline   Reply With Quote
Old 03-16-2010, 08:26 AM   #4
There is andover Tstat, but all I can set is temperatures for heat and cool. I even cannot change the time setting on Tstat. I dug online too, and found the same thing you attached.
I guess even if I changed Tstat, things won't change since all controls are in two andover modules (TCX843 and TCX867).
Old 03-16-2010, 08:21 PM   #5
you will need to check at the furnace board to see if there is power on the g signal
richiemoe is offline   Reply With Quote
Anything wrong with an outlet in the ceiling? Red Squirrel Electrical 12 10-08-2009 08:59 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Ants and avoidance of baits - what am I doing wrong!? joeyboy Pest Control 11 01-14-2008 09:09 PM
Drywall,what am I doing wrong? Feangel Painting 4 06-19-2007 08:17 PM
