What Wrench For A Radiator Fitting - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2008, 06:58 PM   #1
Rewards Points: 150
what wrench for a radiator fitting
i need to replace the small nipple that goes into the radiator that has the half of the union piece on it. i think it is removed by using some kind two prong wrench that goes into the pipe and hits these two pieces of metal. it may called an internal spud wrench? how do i get these out? the radiator i got is 1/2" to wide to fit into the opening and i want to take these fittings out and get a slightly smaller one.
drewhart is offline   Reply With Quote
Old 12-14-2008, 08:01 AM   #2
An old Tradesmen
Rewards Points: 6,458
Radiator Spud wrench.
If installed right, it will come out easy.
If it was over tightened. Use the spud wrench in the fitting, and a pipe wrench on the outside of the spud. Positioned to exert pressure on the wrench, so it doesn't crush the fitting.
You can use a wood dowel to do the same thing.
Old 12-14-2008, 01:51 PM   #3
And don't put any lateral pressure on the valve. Broken fittings are not fun to replace especially with this cold spell we are in.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-14-2008, 03:10 PM   #4
Rewards Points: 150
thank you. does this fitting bottom out? i want this wrench to hopefully tighten these things in about a 1/4" in each side because it is 1/2" to big for the opening in the pipes.
Old 12-14-2008, 03:59 PM   #5
An old Tradesmen
Not sure I follow.
My spud wrench fits into a " spud.
Old 12-14-2008, 07:45 PM   #6
tk03's Avatar
Rewards Points: 150
No, the union does not bottom out. If you are using a new fitting the entire union must be used. You cannot use a new and old union half.
tk03 is offline   Reply With Quote
Old 01-06-2009, 07:27 PM   #7
Rewards Points: 150
i have posted a new question in relation to these issues if anyone wants to read it. beenthere says to use a pipe wrench at the same time, but the nut is to close to the bushing to fit a wrench in. i got one out by sawzalling through and removing the nut. is this a good way to remove them?
Old 01-06-2009, 09:09 PM   #8
An old Tradesmen
LOL...
Sorry, forgot to tell you that part.
Yea, just use a sawzall on the nut, split it off, then use the pipe wrench.
Old 01-07-2009, 12:59 PM   #9
Rewards Points: 150
yeah thats been working good. when i install the new spud, how tight should i make it?
Old 01-07-2009, 05:04 PM   #10
An old Tradesmen
Hard to explain onver the internet.
They don't have to be made as tight as people might think.
But, they must be fairly tight.
Its more of a feel you develope(an art), then an exact science(X turns works everytime thing).
Help! I can't remove a bathtub drain after I broke the crossbars with a wrench andreajohanson Plumbing 18 04-25-2008 12:47 AM
Makita Impact Driver vs Wrench HELP! the496rocket Tools 8 02-14-2006 08:41 PM
