What In The World Is This? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 03:43 PM   #1
What in the world is this?
While changing my Central A/C filters I noticed this green Brillo-pad like thing. What is it? Does it need to be removed, changed, cleaned?
JackOfAllTrades is offline   Reply With Quote
Old 08-25-2011, 03:57 PM   #2
An old Tradesmen
Rewards Points: 8,184
Thats a hog hair air filter. Its probably used to filter the air from a fresh air intake.
Old 08-25-2011, 07:04 PM   #3
REP
As beenthere said. It is considered to be a long lasting filter that can be washed dried and put back in.
It actually is called a "hog Hair " filter But I question if that is what it is really made of or if its what hog hair feels like.
In any case it is sprayed (painted,dyed? )with something that insulates the fibers.
REP is offline   Reply With Quote
Old 08-25-2011, 07:33 PM   #4
Hogs hair is not Kosher.
Master of Cold is offline   Reply With Quote
Old 08-26-2011, 12:03 AM   #5
So do I just rinse it under water, dry it off, and put it back place? How often should this be done?
Old 08-26-2011, 04:20 AM   #6
An old Tradesmen
Yep, wash with water or with soap and then rinse with water, let dry for few minutes then reinstall. Every 90 days or so.
Old 08-26-2011, 07:54 PM   #7
I cleaned it out and put it back.
Behind it there is a sort of hinged flap door with a duct going to the attic. That hinged flap door does not rotate that easily, it seems almost as though it is manually adjusted. Should I adjust it to be open fully, partially or mostly closed?
Old 08-26-2011, 08:46 PM   #8
An old Tradesmen
It should be adjusted to let in just a small amount of fresh air.
Old 08-28-2011, 12:43 AM   #9
What is the purpose of that vent? It seems like a waste of energy as it allows warm outside air into the A/C vents.
Old 08-28-2011, 01:03 AM   #10
An old Tradesmen
Tight houses need fresh air. Some areas have codes that require it on all homes. And on othr homes, it is intended to be the source of combustion/make up air.
Old 08-28-2011, 04:37 PM   #11
Rewards Points: 292
post removed
veesubotee is offline   Reply With Quote
Old 08-28-2011, 04:39 PM   #12
Experienced
Jackofall1's Avatar
I got a laugh out of it........
Mark
What is the best paint in the world? Majid Painting 30 06-23-2012 12:28 PM
window world? analogmusicman Remodeling 7 07-11-2010 07:31 AM
Where in the World Are You? user1007 General DIY Discussions 6 01-25-2010 08:49 AM
If Women Controlled The World.... gma2rjc Off Topic 8 04-13-2009 01:51 PM
ICI - Glidden - Color Your World nzan Painting 1 02-27-2008 06:03 PM
