Old 01-30-2013, 05:24 PM   #1
What is a window that may not open?
The venting instructions for my furnace say the vent has to be 4' from a window that may open, but only 1' from a permanently closed window.
I don't have more than 8' between windows, so that is a serious problem. Can put a screw in though a double hung window to make it a permanently closed window?
Toller is offline   Reply With Quote
Old 01-30-2013, 06:03 PM   #2
New England DIYer
I don't understand that part ^
I think the reason for the min distance from a window is so exhaust won't get sucked into the house. Therefore how far is the vent from the nearest window? About screwing the window shut, that is probably a question for your local inspector, and if that will suffice, my guess is no.
nick26 is offline   Reply With Quote
Old 01-30-2013, 06:06 PM   #3
Since I don't have 8' between windows, there is no point less than 4' from a window.
Old 01-30-2013, 06:17 PM   #4
Hvac Pro
Depends on the local ispector and authorities. If it is siliconed permanently shut that usually is allowed. A screw is too easy to remove after the inspector leaves, just to pass inspection so silicone is a better bet. Should check with them 1st.
Old 01-30-2013, 07:24 PM   #5
Why not just two pipe the furnace, so the clearances wont be an issue?.
HVACTECH96 is offline   Reply With Quote
Old 01-30-2013, 08:15 PM   #6
An old Tradesmen
Yep, direct vent makes it easier to have clearance.
Old 01-31-2013, 10:53 AM   #7
Part of the Clover Leaf
Yep, direct vent. Never use a one pipe set up my self.....
hvac5646 is offline   Reply With Quote
Replacing old kitchen window with new construction window speedster1 Windows and Doors 2 06-29-2012 01:13 AM
Basement window finishing Dmoraski Windows and Doors 3 05-29-2012 04:08 PM
Sizing Window AC For Open Room appleye1 HVAC 17 07-29-2010 11:00 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
