What Will Happen If The AC Unit Is Mounted On The Brick Wall? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 08:09 AM   #16
Originally Posted by JJboy View Post
I think this concrete anchor will work perfect with brick wall but if the wall is coated with brick I don't think it will be strong.
Will it fall down eventually? Would the wall be damaged?
lameon is offline   Reply With Quote
Old 06-26-2012, 10:33 AM   #17
If a structure was designed to hold a condenser this wouldn't be an issue. However, you stated that there was a concrete pad it used to sit on. If installed properly there would have to be access on the other side of the wall. Meaning, sheetrock would have to be removed and blocking installed. If they just attached a platform to the brick using a wedge anchor, epoxy, tapcons, or how ever they did it, I can't imagine it holding for long. Yes, those things vibrate, and yes eventually it will jiggle the bricks enough to break the grout. What kind of "brick" is it? Sneak over there and take a photo, cuz I think we ALL would love to see it.
CopperClad is offline   Reply With Quote
Tags
ac "outdoor unit" mount
Attaching Willow Screen to brick wall tripled Landscaping & Lawn Care 5 08-12-2011 06:46 AM
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 08:07 AM
max distance of AC unit to house wall tar HVAC 5 09-05-2008 06:26 AM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
