What Will Happen If The AC Unit Is Mounted On The Brick Wall? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 12:54 AM   #1
What will happen if the AC unit is mounted on the brick wall?
My neighbour installed a AC recently, I found that the outdoor unit is mounted on the brick wall but not the concrete base. Somebody says this is not good. Anyone can tell me why? Thanks!
lameon is offline   Reply With Quote
Old 06-24-2012, 12:57 AM   #2
Are you saying someone mounted the condenser to the brick wall...of a house???
CopperClad is offline   Reply With Quote
Old 06-24-2012, 01:09 AM   #3
Yes, that's what I meant. Very rare, but it did happen. So I asked my question.
Old 06-24-2012, 01:16 AM   #4
And your here asking what is the problem with that???? Tell me one thing that is right with it and we'll go from there.... Better yet. Enlighten me as to how one attaches a condenser to a brick wall.
Old 06-24-2012, 01:23 AM   #5
JJboy's Avatar
LOL
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-24-2012, 05:48 AM   #6
An old Tradesmen
Rewards Points: 6,464
http://www.alpinehomeair.com/viewpro...ctID=453059689
Old 06-24-2012, 07:47 AM   #7
I'm Your Huckleberry
Rewards Points: 2,270
Is there a possiblility of you taking a picture and posting it here? If I'm thinking what this may be then it's not all that uncommon to see them up in the air on a side of all sorts of buildings, residential or commercial, sitting on a pre-fab metal ledge. Prevents theft is the biggest deal.
Much harder to service but we just charge more.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-24-2012, 12:59 PM   #8
Brick is not structural. Mounting bolts would need to go all the way through the brick and anchor into backing plates in the wall.
The Following User Says Thank You to Marty S. For This Useful Post:
CopperClad (06-24-2012)
Old 06-24-2012, 04:17 PM   #9
An old Tradesmen
May be installed with thru bolts, that the OP doesn't know about.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
plummen (06-26-2012), Tom Struble (06-24-2012)
Old 06-25-2012, 09:31 AM   #10
Then what will happen? Will the it damage the wall eventually with the vibration? Or anything else? At least I heard big noise while it's running.
Old 06-25-2012, 10:28 AM   #11
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Are you sure it's not a mini-split?
CoconutPete is offline   Reply With Quote
Old 06-25-2012, 10:35 AM   #12
Yes, I'm 100% sure it's a regular residential AC condenser. And the building is a end unit of a townhouse. The unit is mounted on the side wall.
Old 06-25-2012, 11:01 AM   #13
JJboy's Avatar
This support?
Old 06-25-2012, 11:04 AM   #14
Originally Posted by JJboy View Post
This support?
Yes, something like this. But the wall is a brick wall. Is it really a bad thing, or just ok?
Old 06-25-2012, 11:31 AM   #15
JJboy's Avatar
I think this concrete anchor will work perfect with brick wall but if the wall is coated with brick I don't think it will be strong.
http://www.confast.com/products/drop-in-anchor.aspx
Tags
ac "outdoor unit" mount
Attaching Willow Screen to brick wall tripled Landscaping & Lawn Care 5 08-12-2011 07:46 AM
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 09:07 AM
max distance of AC unit to house wall tar HVAC 5 09-05-2008 07:26 AM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 11:07 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
