What Wall Switch For Bath Fan/light/heater? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2009, 07:45 PM   #1
Rewards Points: 85
What wall switch for bath fan/light/heater?
What type wall switch do I need for a Panasonic FV-11VHL2 bathroom exhaust fan that includes an exhaust fan, heater, light, & night light? I'm replacing an old unit that has all the same functions except the night light & the old unit uses a 3-toggle (fan, heater, light) switch in one regular sized box. Apparently, Panasonic doesn't make the switches. I assume I'll need a 4-function switch to handle the extra night light...is that correct? If so, is there a 4-function switch out there that fits in one regular sized box? Or, do I have to add a second single sized box, or a double sized box, or what? If I have to add a second single sized box, would it be advisable to keep the fan & two light functions in one box & install a rotary-type timer switch in a second box for the heater? And who makes whatever switches you may recommend?
I really appreciate any advice.
janralix is offline   Reply With Quote
Old 07-18-2009, 09:09 PM   #2
http://service.us.panasonic.com/OPERMANPDF/FV11VH2.pdf
You can go with something as simple as a double gang
http://www.iaqsource.com/product.php...rce.com-171839
http://shopping.aol.com/4-function-d...hite/714122498
G17GUY is offline   Reply With Quote
Old 07-18-2009, 10:04 PM   #3
Rewards Points: 85
What wall switch...
Thanks...exactly what I needed to know!
Old 07-18-2009, 10:29 PM   #4
Rewards Points: 85
Will I need additional wiring? Thanks.
Old 07-19-2009, 10:35 PM   #5
You will need six wires from your box to your fan. A ground, neutral and 4 switched hots.
Old 07-19-2009, 10:54 PM   #6
drew you a picture
What wall switch for bath fan/light/heater?-fan.jpg
Old 07-20-2009, 01:32 AM   #7
Rewards Points: 85
Thanks for all the good information.
Now I have found this: Broan makes a model 77DV (& 77DW) that has all the functions in a single gang box. Shouldn't this work with the Panasonic fan I referenced?
Old 07-20-2009, 02:23 AM   #8
Yep looks like it willl work, just don't put the heater on the 3 position rocker swich. Put it on a 2 position switch as they are rated for 15 amps.
Old 07-20-2009, 05:07 PM   #9
Rewards Points: 85
Great! That will fit my current space & not be so big.
Thanks.
This is a great place for answers!
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Wall switch for Ceiling Fan / Light Bocolo Electrical 3 03-08-2009 10:56 PM
Adding an outlet to a wall switch Keyo77 Electrical 6 01-02-2008 12:22 AM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 09:13 AM
Wall Switch sue Electrical 4 02-06-2005 08:05 PM
