At What Voltage Is A 24v Transformer Considered Too Weak? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 11:18 AM   #31
Originally Posted by SULTINI View Post
Philp
Your statement problem solved - at least for now.
Is a true statement once a valve sticks it will do it again and it will at the time you least expect it 20o outside, holidays, weekends, middle of night.
So the point being replace it ASAP because it will let you down again.
Be prepared.
Better listen to Sultini, he is so right. If that valve sticks open it will do it again.
hvaclover is offline   Reply With Quote
Old 12-08-2009, 02:04 PM   #32
Originally Posted by beenthere View Post
10.
Apply the math. And you'll see it doesn't work out like you thing.
"A 24v 40 VA 'frmr with 26v open circuit voltage, at 21v, is delivering ~4A. "
40/24 = 1.67 A full load current
24/1.67 = 14.4 ohms full load resistance value
26/(Rint + 14.4) = 1.67A Assuming the 'frmr internal impedance is mostly resistive
26/1.67 = (Rint + 14.4) = 15.6 ohms
Rint = 1.17 ohms
4A x 1.17 = 4.7 v
26-4.7 = 21.3v
Old 12-08-2009, 04:34 PM   #33
It's not a resistive load. It's inductive.
Old 12-08-2009, 04:49 PM   #34
An old Tradesmen
Rewards Points: 7,746
As clover stated, a solenoid is an inductive load.
Ohm's laws, only apply to resistive loads. And are for DC.
And we are talking AC, not DC.
While it can be used on AC loads. It is not 100% accurate.
So it won't work out in many cases, And this topic, is one of those cases.
There are formulas for it though.
Old 12-08-2009, 05:00 PM   #35
Ay, yi, yi. . .
Old 12-08-2009, 05:07 PM   #36
An old Tradesmen
Originally Posted by Yoyizit View Post
Ay, yi, yi. . .
Come and spend 10 or 20 year on the dark side. And then you will understand.
Old 12-08-2009, 05:26 PM   #37
Is growing up in NJ enough of a Dark Side for you?
And may the Farce be with you!
Old 12-08-2009, 05:50 PM   #38
An old Tradesmen
Nah, jerseys just talk funny.
Old 12-09-2009, 11:05 AM   #39
Pronunciation guide to NJ:
Jersey = Joisey
dog= dawg
coffee = cawfee
father = fada
mother = mudda
What do you = whaddya'
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 08:21 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
Hard wired Low Voltage Transformer? VistaV Electrical 9 04-25-2008 10:04 AM
Generator Output Question gimmeda8 Electrical 11 03-06-2008 11:15 AM
