What Type Of Motor Do I Need For My Attic Fan? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 08:00 AM   #1
Ummmm...
Shpigford's Avatar
Question
What type of motor do I need for my attic fan?
My attic fan motor appears to be on the fritz (makes a buzzing sound and the fan tries to turn but won't make it more than 1-2 revolutions without sticking).
I'm trying to figure out what type of motor I need. Here are potentially relevant bits of info about the fan/motor...
  • 14-inch blade/housing
  • 120V
  • 2.1A
  • 60Hz
  • 1/5HP
I'm having trouble finding a motor that meets all of those numbers and wasn't sure which of those numbers actually mattered.
FWIW, I have a ~2500 sq/ft attic space.
Shpigford is offline   Reply With Quote
Old 07-27-2012, 08:40 PM   #2
Rewards Points: 516
Try starting here:
http://www.amazon.com/s/?ie=UTF8&key...l_5lzf8m9v1j_b
diyorpay is offline   Reply With Quote
Old 07-27-2012, 09:21 PM   #3
Rewards Points: 582
try ..www.grainger....or johnstone supply...
Old 07-28-2012, 06:28 AM   #4
DIY staff
Rewards Points: 7,174
Menards stocks those also--
Old 07-28-2012, 06:50 AM   #5
AKA HVACTECHFW
Rewards Points: 1,208
Do a google search for XE404
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-28-2012, 08:59 AM   #6
HVAC Contractor
Rewards Points: 336
Lowes and Home Depot in my areas stock the fans. They're about $80 bucks or so I believe.
scottmcd9999 is offline   Reply With Quote
Old 07-28-2012, 11:11 AM   #7
Rewards Points: 6,652
Cheaper to just buy the whole unit and pull the fan and thermostat off of the new one, install in the old housing.
Old 07-28-2012, 11:17 AM   #8
Rewards Points: 1,192
www.repairclinic.com
bobelectric is offline   Reply With Quote
Old 07-28-2012, 11:46 AM   #9
AKA HVACTECHFW
the problem I found was that your fan has a PSC motor most are shaded pole. The XE404 is the correct replacement for your motor.
IT IS WHAT IT IS
Tags
attic , fan , motor , ventilation
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 07:49 PM
Attic venting questions lemmy Roofing/Siding 36 05-28-2011 08:14 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
