What Type Low Voltage Wire For T-Stat?? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 02:51 PM   #1
Rewards Points: 77
What type Low Voltage Wire for T-Stat??
Hello,
My split system central AC just went in. My installer/friend used an Aprilaire 8600 T-Stat. He's had great luck with those. They make an optional Outdoor temperature sensor (add-on) that I would like to install :
http://estore.aprilaire.com/catalog/...fier-parts/291
What type of Wire can I use with this as I'll need to splice it to extend the cable back to to the T-Stat.
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 05-10-2012, 03:27 PM   #2
Rewards Points: 484
Thermostat wire is fine. Big box store will have 18/2.
sammy37 is offline   Reply With Quote
Old 05-11-2012, 09:41 AM   #3
Rewards Points: 214
I just installed the Aprilaire 8463 thermostat and quite happy with it. It's very easy to program and user friendly. I used tstat wire for the temp gauge as well.
Good luck
Ralph III is offline   Reply With Quote
Old 05-11-2012, 11:11 AM   #4
Rewards Points: 6,652
Bell wire is what it is usually called. Go to Lowe's or Home Depot. If not in the electrical aisle, it may be where they keep the thermostats and ducting, etc..
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
What type of wire should I be using? Zellarman Electrical 27 12-04-2011 06:44 PM
Correct type of wire for a 100 amp, 160 ft run SRedinbo Electrical 8 05-01-2011 07:18 AM
voltage on earth wire Spikeyboy Electrical 13 10-15-2010 12:03 PM
Low voltage wire entering/exiting walls need box? Azeiku Electrical 2 07-07-2008 05:55 PM
