Old 10-29-2009, 07:49 AM   #1
Default What type of heating for garage
OK,
I just finished insulating the garage… Man that expanding stuff is $$$$$! I also added the grey stuff as I had 4” left after the expanding stuff – better over kill than none seeing as there are bedrooms above the garage.
Anyhow, I have two registers in the garage which are connected to my HVAC and this is not code, so I have to cancel them. I fished 220V wire in the garage before closing the walls and ceiling with gypsum.
So my question is this: Which is more efficient – baseboard radiant heaters or one of those electric blown air type garage heaters? I am in Montreal and our electric is not quite as expensive. Those heat pump type heaters are VERY efficient, but ???? in comparison.
Any ideas are welcome.
Thanks in advance.
Frank
Franky123 is offline   Reply With Quote
Old 10-29-2009, 01:21 PM   #2
An old Tradesmen
Neither.
Electric heat is 100% efficient.
The radiant may give you a more comfortable heat. but will take longer to warm up the garage then a forced air one.
While a heat pump PTAC may be more money up front. It will cost far less to use.
Old 10-29-2009, 02:49 PM   #3
Oh Yeah, Far less!! I just did a comparison search and the heat pump is 300% more effecient. Cheapest one I could find for the space is 800 bucks.... Thanx,
Old 10-29-2009, 04:33 PM   #4
An old Tradesmen
Your welcome.
They are 300% or more efficient at temps of say 35 and above. As it gets colder, they lose efficiency. But, are still more efficient at 10° outdoor temp then straight electric heat.
More On This Topic
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Learn the guitar parts to adjust to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-11-2009 12:09 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 06:50 AM
Heating Unit farooq Plumbing 2 07-18-2008 07:23 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 09:27 PM
In-Floor Heating Cable Trouble... sootybuttercup Electrical 9 10-28-2006 07:32 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
