What Type Of Duct? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 12:35 PM   #1
What type of duct?
I'm trying to determine if my HVAC vendor installed the correct type of duct for my Vent-a-Hood cooking vent. The picture in this thread is what he installed. Vent-a-hood requires Smooth Duct, not Flexible or Corrugated.
What kind of duct is this?
Thanks.
gilliganslin is offline   Reply With Quote
Old 07-14-2013, 12:53 PM   #2
Looks like a smooth, 90 elbow that's been straightened out to me.
VIPlumber is offline   Reply With Quote
Old 07-14-2013, 02:26 PM   #3
Experienced HVAC Tech
HVAC1000's Avatar
Thanks.
Definitely smooth
HVAC1000 is offline   Reply With Quote
Old 07-14-2013, 06:40 PM   #4
Rewards Points: 1,456
That's an adjustable elbow. It is smooth and rigid so you're fine there. No idea why they would use that instead of a solid pipe. It's definitely more expensive and slightly harder to work with. You can tape that joint at top if you'd like to avoid getting funk in your cabinet. Technically, each one of those seams leaks, but shouldn't matter at that pressure.
mikegp is offline   Reply With Quote
Old 07-14-2013, 06:43 PM   #5
MarginallyQualified
Rewards Points: 2,464
closest thing to the back of a long truck.
The Following User Says Thank You to TarheelTerp For This Useful Post:
HVAC1000 (07-14-2013)
Old 07-15-2013, 05:01 AM   #6
Thanks for all the replies.
how to replace a section of CAC duct in wall? diy'er on LI HVAC 5 03-12-2012 12:16 AM
Raising a suspended heat duct dmarek HVAC 2 04-17-2011 04:57 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
Microhood vent location, diameter, duct type? pcampbell Appliances 6 03-20-2008 06:07 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
