What Trips A Roll Out Safety Switch? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 10:41 AM   #1
what trips a roll out safety switch?
I have a Payne gas hot air furnace. Furnace cycles as it should ..fires up, blower motor and inducer?(to vent gasses) motor run. 1 or 2 minutes roll out switch trips. its a manual reset, so wait till everything cools down. Reset the switch, same thing happens. So could a dirty "A"evaporator coil be causing this and if so how can I clean it?
thanks,
Chris
grizzly is offline   Reply With Quote
Old 10-18-2009, 10:57 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Where exactly is this switch? Post a pic of it. If it is on the side of the ventor fan to the chimney then you may have a blocked chimney or dead bird in the pipe immediately above it (yes it happens).
Old 10-18-2009, 10:58 AM   #3
a tripped roll out switch is an indication that the heat exchanger may have a crack.
Flashheatingand is offline   Reply With Quote
Old 10-18-2009, 11:14 AM   #4
yuri,
That is exactly where its located. if pics load, they are from my phone using a flashlight for light.
but it it attached to a small box which is attached to the upsteam side of the fan that blows the gasses out of the combustion chamber
what trips a roll out safety switch?-matt-wedding-036.jpg   what trips a roll out safety switch?-matt-wedding-037.jpg
Old 10-18-2009, 11:15 AM   #5
top pic is correct orientation
Old 10-18-2009, 11:51 AM   #6
Yuri
"YOU DA MAN"
dead pigeon
thank you very much,
chris
what trips a roll out safety switch?-pigeon-001.jpg   what trips a roll out safety switch?-pigeon-003.jpg
Old 10-18-2009, 11:53 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 396
I make good $$ doing service calls and removing our feathered "friends". Usually they are the smaller variety, that was a real dumb one.
You can get bird proof chimney caps and make sure you at least have a basic one.
Old 10-18-2009, 03:49 PM   #8
Yuri be psychic.
Mr. Grizzly, your CO detectors didn't go off?
Old 10-18-2009, 04:33 PM   #9
no, it only cycled for a minute or 2, each time. its a pretty big area and detectors are on the other side....25 feet away located by the stairs.
but there is one(carbon monoxide and smoke) on each floor. our last house, the heat exchanger rusted thru and we had a carbon monoxide issue. so that won't happen again.
thank you for your concern,
chris
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
New switch trips breaker dcast79 Electrical 9 03-22-2009 08:05 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Switch trips Breaker pvrio Electrical 4 09-21-2008 04:53 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
