What Tonnage Is My Outside Ac Unit? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 04:19 PM   #1
What tonnage is my outside ac unit?
The tag on the unit with all the specs is attached.
I have to replace the evaporator coil due to a freon leak.
Please point me to a link that is compatible.
dimensions are as follows: 35.5 x 25 x 12
THanks!
What tonnage is my outside ac unit?-img00216-20110713-1559.jpg   What tonnage is my outside ac unit?-img00151-20110628-2016.jpg
blarose is offline   Reply With Quote
Old 07-13-2011, 05:30 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,778
49,000 BTU = 4 ton 1996 R22 unit. I would replace both the indoor coil and condensor as the SEER rating on that unit is 10 or less. Condensors nowadays are 13 SEER or higher and won't work with your old coil properly.
Old 07-13-2011, 06:12 PM   #3
Ok thanks for the answer.
I am going to be moving next year, so probably will just replace the evap coil unless there is something else I should be aware of.
Old 07-13-2011, 06:22 PM   #4
Hvac Pro
yuri's Avatar
The new evap coil will be a 13 SEER and may not work well with your older 10 SEER or lower condensor. Won't get the proper freon pressures and coil temp and won't dehumidify properly. Hang in here some of the other Pro's may have a workaround or other ideas. My company would not take on that job. NO way we could get it to work properly or guarantee any performance from it.
Old 07-13-2011, 06:50 PM   #5
How fast does it leak out? An option is just fill it up to get through this summer then give the new owners the cost of the coil to apply towards a new system of their choice.
Old 07-13-2011, 07:50 PM   #6
It was filled 1 month ago and level on the gauge is already down to 60.
Also I meant to say dimensions of current coil is 33.5 x 25 x 12.
Old 07-13-2011, 09:24 PM   #7
Can anyone point me to a link that has a compatible evap coil for my system?
Old 07-13-2011, 09:44 PM   #8
Rewards Points: 6,652
Possibly not. I would just give open disclosure when you go to sell, and take the risk that the house will not sell, due to non-working hvac equipment, or take the bite, and update the air handler/furnace & outside unit, and have a better sell on the house, because it has updated hvac equipment, compared to the other houses that may already be on the market that are not selling, or may be on the market at that time you go to sell.
The more you can update the home (hvac, water heater if over 10 years, Windows/doors, Kitchen, Bath, flooring, painting, roof, garage door), you have a better chance of selling the house quicker, than those that do nothing to it.
Old 07-13-2011, 09:44 PM   #9
I'm Your Huckleberry
Rewards Points: 2,270
Are those measurements the openings of the coil or the entire cabinet? You want the actual opening.
Doc Holliday is offline   Reply With Quote
Old 07-13-2011, 09:46 PM   #10
JJboy's Avatar
Ask your local dealer. When you get the correct replacement, you can search online as well.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-13-2011, 09:59 PM   #11
That is the entire cabinet.
the actual opening is about 25 x 21
Old 07-13-2011, 10:04 PM   #12
Not sure I quite understand. I have had 2 separate hvac companies quote me for just the evap coil replacement. They said it is best to replace everything together, but none of them have mentioned any bit of it not working.
If I do replace the condensor, can I just replace the outside unit and evap coil or does the furnace need to be replaced also?
I hate to get a whole new system as I will not receive a full return on investment. If I can get the system operational, I believe that isn't great but satisfactory to the average home buyer.
Thanks for the help!
Old 07-13-2011, 10:07 PM   #13
30 year tech
hvac122's Avatar
As said, there is no compatable coil for your system. I think you will have a hard time finding a coil with those dimensions. If you do have a txv installed as it is the best option to get it working close to right.
hvac122 is offline   Reply With Quote
Old 07-13-2011, 10:12 PM   #14
You need the exact opening dimensions. That is what we use when we replace evaporator coils, not the cabinet.
Old 07-13-2011, 10:18 PM   #15
Seems odd that I cannot replace what is broken and I need to replace everything. If I had the money I would.
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 03:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 07:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
