What Is This Thing? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 07:36 AM   #31
Rewards Points: 154
From the engineering toolbox website.
The simplest steam heating system is the
Single Pipe Steam System with Main Pipes Pitched Towards the Boiler
Steam and condensate use the same main pipes. The condensate flows in the opposite direction of the steam.
Air valves are necessary for evacuating air during start-up.
The system is simple but the heat emission in radiators or in heat exchangers are hard to control. Modulating the heat will cause the heating elements to be partly filled with air. The system can work properly in applications where the heat can be modulated directly in the boiler, as applications for warehouses, garages and so on. The system should be avoided where it is necessary to individually modulate each radiator or heat exchanger.
The condensate draines back to the boiler and during stops the system fills with air. This makes the design suitable for temporarily heated application working under water freezing conditions.
Patrick Eubanks is offline   Reply With Quote
Old 10-11-2012, 10:28 AM   #32
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
Sorry, but I just read this post. To back-track for a minute..... ARE YOU SERIOUS?? I do not mean to insult the original poster, but who doesn't know what a radiator is?? Were you raised in the forest by wolves or something? I think this post was a joke. If not, I am sorry.
p.s., that bright shiny thing in the sky is the Sun.....
Oh-Fudge is offline   Reply With Quote
The Following User Says Thank You to Oh-Fudge For This Useful Post:
gregzoll (10-11-2012)
Old 10-11-2012, 09:15 PM   #33
Thread killer
Rewards Points: 272
I see you can find schematics, too bad the info is incorrect. Both 2 pipe and 1 pipe steam should run at a couple of pounds of steam. pipe sizes are bigger on 1 pipe than 2, for obvious reasons. BOTH systems let air in at the end of a cycle but while its easy to see on a 1 pipe system because the vents are on each rad, the 2 pipe system venst are on the mains, with the heating unit. Properly maintained, there will be minimal difference between the two.
Here's a link to explain how TRV's work on 1 pipe steam
http://www.heatinghelp.com/files/posts/8569/TRVs.pdf
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 10-12-2012, 09:21 PM   #34
Missouri Bound's Avatar
And you apparently know everything about everything? I"ve never lived in a home with a radiator, and yes I know what one is. And I also know what a smart is.
Do you want it your way or the right way?
Old 10-15-2012, 12:36 PM   #35
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
My point exactly.
Old 10-15-2012, 01:04 PM   #36
Rewards Points: 610
very entertaining reading!....steam sucks.. that's why most have gone with hot water which can be much better controlled via regulating valves and outdoor reset controls to vary system water temp...Steam is always above 212 deg F!!...so much for control..no thanks!
techpappy is offline   Reply With Quote
What's the worst thing you've found after midnight? Leah Frances Off Topic 34 01-04-2015 12:43 AM
Didn't have the 'green thing' back in our day gma2rjc Green Home Improvement 6 07-05-2012 06:23 AM
What is this thing? A well? Or nothing? jkeuning Landscaping & Lawn Care 9 04-04-2012 01:54 PM
Replacing a fiberglass curtain thing with an actual bedroom door. jde0503 General DIY Discussions 9 08-05-2011 10:13 AM
Bryant 394G Blower Motor - How do I lubricate this thing? JohnCoffey HVAC 2 06-19-2008 09:05 PM
