Old 10-19-2009, 10:39 AM   #1
Default What thermostat to buy?
I installed a honeywell RTH 221 but have found that with my system I get only hot air when on the cold setting and equally hot air on the heat setting. I need a suggestion on what to buy. The system is a Lenox installed when built in 1996. I have been informed by a member here that I bought the wrong thermostat and the wire connected to the O terminal was important! Even though the insallation manual said that some wires may not need be connected with newer thermostat and there was no terminal for the O or the C1 ( I beleive) it was a blue wire. Thank you all!
jayres is offline   Reply With Quote
Old 10-19-2009, 03:54 PM   #2
post model numbers to your system
firedogut is offline   Reply With Quote
Old 10-19-2009, 07:44 PM   #3
An old Tradesmen
If you have a heat pump.
You NEED a terminal for the heat pumps revering valve.
Makes no difference what heat pump it is. they ALL need a thermostat that has O, B, or O/B terminal.
More On This Topic
Hi, I'm Peter D' Alessandro with Expert Village. So in tying this up, I'm going to plug it I'm going to terminate both ends of the wire. Plugged in. And you can find wire ties almost any color. So I'll start to do this. I'll bundle up. Be very gentle on... Read More »
Today we are replacing a bad thermostat. Now once you have it removed from the wall, you’ll have to scrape this and repaint it, I’m sure. But you want to make sure to get the right thermostat because you can cause some damage to your A/C or... Read More »
Hi, I am Drew Fendy here today to demonstrate how to install a jack for your telephone for ExpertVillage.com. The different types of wire is very important and if you need help you can go to your local store and talk to the people there about which is... Read More »
Hello, I'm Statia Widak. I'm from Plainview Massachusetts and I love collecting glass. It is my hobby. I'm here on behalf of Expert Village. This is where I keep my china and it's used almost every day, every other day and we have a lot of leaded glass... Read More »
How to Test a Car Battery
How to Test a Car Battery by Expert Village
In this clip we're going to talk about the proper service procedure to remove, inspect and overhaul your vehicles alternator. In this step we're going to talk about the proper service procedure to check the vehicles wiring and insure that's not the... Read More »
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 07:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-03-2009 12:07 AM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 11:21 AM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 06:26 AM
Thermostat compatibility sfbike2003 HVAC 0 11-23-2007 11:15 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
