-   -   What thermostat to buy? (http://www.diychatroom.com/f17/what-thermostat-buy-55496/)
jayres 10-19-2009 09:39 AM
I installed a honeywell RTH 221 but have found that with my system I get only hot air when on the cold setting and equally hot air on the heat setting. I need a suggestion on what to buy. The system is a Lenox installed when built in 1996. I have been informed by a member here that I bought the wrong thermostat and the wire connected to the O terminal was important! Even though the insallation manual said that some wires may not need be connected with newer thermostat and there was no terminal for the O or the C1 ( I beleive) it was a blue wire. Thank you all!
firedogut 10-19-2009 02:54 PM
post model numbers to your system
beenthere 10-19-2009 06:44 PM
If you have a heat pump.
You NEED a terminal for the heat pumps revering valve.
Makes no difference what heat pump it is. they ALL need a thermostat that has O, B, or O/B terminal.
