What Is The Temperature Of The Water In A Water To Air AC Unit? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 10:24 AM   #1
Rewards Points: 184
What is the temperature of the water in a water to air AC unit?
What typically is the temperature of the water in a water to air AC unit?
Do they still use freeon in those?
abefroman is offline   Reply With Quote
Old 04-02-2009, 10:33 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
A chilled water coil runs in the 50 degF or less range and the cool water is produced by a chiller or refrigeration unit which nowadays uses the less ozone depleting refrigerants. Freon is a generic name invented by DuPont I believe.
Old 04-02-2009, 11:08 AM   #3
Rewards Points: 184
Thanks!
Is the chilled water more efficient or less expensive than a condenser type unit, or is a condernser all around better?
Old 04-02-2009, 11:10 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
Not sure why you are asking. Chilled water is for multiple condos and large commercial/institutional jobs (hospitals etc) with one large over 50 ton unit. Efficiency has to do with the design of the machine.
Old 04-02-2009, 11:14 AM   #5
Rewards Points: 184
Just curious, there are some condos, that have an individual condenser for each unit on the roof from what I've been told.
Old 04-02-2009, 11:17 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 396
FYI: Chillers:http://www.trane.com/Commercial/DNA/View.aspx?i=975
The units you see are probably your average freon split system with condensor on roof.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
sudden change in water temperature to hot rolittleton Plumbing 2 12-29-2008 08:17 AM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
